Merge branch 'bug_12454' into 'master'
[oar-properties] Set initial state of new nodes to Absent (bug 12454) See merge request !154
- lib/refrepo/gen/oar-properties.rb 2 additions, 2 deletionslib/refrepo/gen/oar-properties.rb
- spec/oar_properties_spec.rb 49 additions, 49 deletionsspec/oar_properties_spec.rb
- spec/output/dahu_empty_print_stdout.txt 256 additions, 256 deletionsspec/output/dahu_empty_print_stdout.txt
- spec/output/graffiti_empty_print_stdout.txt 208 additions, 208 deletionsspec/output/graffiti_empty_print_stdout.txt
- spec/output/graphite_empty_print_stdout.txt 64 additions, 64 deletionsspec/output/graphite_empty_print_stdout.txt
- spec/output/grimoire_empty_print_stdout.txt 128 additions, 128 deletionsspec/output/grimoire_empty_print_stdout.txt
- spec/output/grue_empty_print_stdout.txt 160 additions, 160 deletionsspec/output/grue_empty_print_stdout.txt
- spec/output/yeti_empty_print_stdout.txt 256 additions, 256 deletionsspec/output/yeti_empty_print_stdout.txt
Loading
