Commit 3d5e6b50 authored by Lucas Nussbaum's avatar Lucas Nussbaum
Merge branch 'fix_get_oar_properties_error_header' into 'master'
[oar-properties] fix get oar properties error header
See merge request !13
parents 1d05197a e9bf86e5
1 merge request!13[oar-properties] fix get oar properties error header
Pipeline #86886 passed
......@@ -673,7 +673,7 @@ def generate_oar_properties(options)
when 2
# Give more details
if header == false
puts "Output format: ['~', 'key', 'old value', 'new value']"
puts "Output format: [ '-', 'key', 'value'] for missing, [ '+', 'key', 'value'] for added, ['~', 'key', 'old value', 'new value'] for changed"
header = true
if diff.empty?
