add spec tests for cases of misconfigured resources (core, gpu, quirk cluster)
- spec/oar_properties_spec.rb 234 additions, 0 deletionsspec/oar_properties_spec.rb
- spec/stub_oar_properties/dump_oar_api_configured_server_misconfigured_cores.json 2978 additions, 0 deletions...s/dump_oar_api_configured_server_misconfigured_cores.json
- spec/stub_oar_properties/dump_oar_api_configured_server_misconfigured_gpu.json 2446 additions, 0 deletions...ies/dump_oar_api_configured_server_misconfigured_gpu.json
- spec/stub_oar_properties/dump_oar_api_configured_server_quirk_cluster.json 2978 additions, 0 deletions...perties/dump_oar_api_configured_server_quirk_cluster.json
Loading
