Commit 2bd1221d authored by Jérémie Gaidamour's avatar Jérémie Gaidamour
[All] Fix misplaced ht_enabled entries
parent 8d1b62cd
...@@ -85,7 +85,7 @@ ...@@ -85,7 +85,7 @@
"cstate_driver": "intel_idle", "cstate_driver": "intel_idle",
"cstate_governor": "menu", "cstate_governor": "menu",
"cstate_max_id": 2, "cstate_max_id": 2,
"ht_enabled": false, "ht_enabled": true,
"kernel": "3.16.0-4-amd64", "kernel": "3.16.0-4-amd64",
"name": "debian", "name": "debian",
"pstate_driver": "intel_pstate", "pstate_driver": "intel_pstate",
...@@ -106,7 +106,6 @@ ...@@ -106,7 +106,6 @@
"cache_l3": 15728640, "cache_l3": 15728640,
"clock_speed": 2000000000, "clock_speed": 2000000000,
"ht_capable": true, "ht_capable": true,
"ht_enabled": true,
"instruction_set": "x86-64", "instruction_set": "x86-64",
"model": "Intel Xeon", "model": "Intel Xeon",
"other_description": "Intel(R) Xeon(R) CPU E5-2630L 0 @ 2.00GHz", "other_description": "Intel(R) Xeon(R) CPU E5-2630L 0 @ 2.00GHz",
"ht_enabled": true,
"ht_enabled": true,
"ht_enabled": true,
"ht_enabled": true,
"ht_enabled": true,
"ht_enabled": true,
"ht_enabled": true,
"ht_enabled": true,
"ht_enabled": true,
"ht_enabled": true,
"ht_enabled": true,
"ht_enabled": true,
"ht_enabled": true,
...@@ -84,7 +84,7 @@ ...@@ -84,7 +84,7 @@
...@@ -105,7 +105,6 @@ ...@@ -105,7 +105,6 @@
"ht_enabled": true,
"ht_enabled": true,
...@@ -108,7 +108,7 @@ ...@@ -108,7 +108,7 @@
...@@ -129,7 +129,6 @@ ...@@ -129,7 +129,6 @@
"ht_enabled": true,
"other_description": "Intel(R) Xeon(R) CPU E5-2620 0 @ 2.00GHz", "other_description": "Intel(R) Xeon(R) CPU E5-2620 0 @ 2.00GHz",
"ht_enabled": true,
"ht_enabled": true,
"ht_capable": true,
