Commit 2b13ff16 authored by Émile Morel's avatar Émile Morel
[lyon] sagittaire - values from g5kchecks
parent 88cf30dd
"architecture": { "architecture": {
"platform_type": "x86_64", "platform_type": "x86_64",
"smp_size": 2, "smp_size": null,
"smt_size": 2 "smt_size": 2
"bios": {
"release_date": "04/25/2006",
"vendor": "Phoenix Technologies Ltd.",
"version": "V1.35.2.2"
"chassis": {
"manufacturer": "Sun Microsystems",
"name": "Sun Fire V20z",
"serial": "XG052536201"
"gpu": { "gpu": {
"gpu": false "gpu": false
"main_memory": { "main_memory": {
"ram_size": 2147483648, "ram_size": 2109751296,
"virtual_size": null "virtual_size": null
"monitoring": { "monitoring": {
...@@ -16,6 +26,8 @@ ...@@ -16,6 +26,8 @@
"network_adapters": [ "network_adapters": [
"bridged": false,
"device": "eth0",
"driver": "tg3", "driver": "tg3",
"enabled": true, "enabled": true,
"interface": "Ethernet", "interface": "Ethernet",
...@@ -35,6 +47,7 @@ ...@@ -35,6 +47,7 @@
"ip": "172.16.49.1", "ip": "172.16.49.1",
"ip6": "fe80::209:3dff:fe12:9e14",
"mac": "00:09:3d:12:9e:14", "mac": "00:09:3d:12:9e:14",
"management": false, "management": false,
"model": "BCM5704", "model": "BCM5704",
...@@ -43,14 +56,28 @@ ...@@ -43,14 +56,28 @@
"network_address": "sagittaire-1.lyon.grid5000.fr", "network_address": "sagittaire-1.lyon.grid5000.fr",
"rate": 1000000000, "rate": 1000000000,
"switch": "gw-lyon", "switch": "gw-lyon",
"switch_port": null,
"vendor": "Broadcom" "vendor": "Broadcom"
"device": "bmc",
"driver": "bnx2",
"enabled": true,
"ip": "172.17.49.1",
"mac": "00:09:3d:12:9e:15",
"management": true,
"mountable": false,
"mounted": false,
"network_address": "sagittaire-1-bmc.lyon.grid5000.fr",
"rate": 1000000000
"operating_system": { "operating_system": {
"kernel": "2.6.32", "kernel": "2.6.32-5-amd64",
"name": "Debian", "name": "debian",
"release": "6.0", "release": "Squeeze",
"version": null "version": "6.0.6"
"performance": { "performance": {
"core_flops": 3929000000, "core_flops": 3929000000,
...@@ -58,15 +85,16 @@ ...@@ -58,15 +85,16 @@
"processor": { "processor": {
"cache_l1": null, "cache_l1": null,
"cache_l1d": null, "cache_l1d": 65536,
"cache_l1i": null, "cache_l1i": 65536,
"cache_l2": 1048576, "cache_l2": 1048576,
"clock_speed": 2400000000.0, "cache_l3": 0,
"instruction_set": "", "clock_speed": 2394000000,
"instruction_set": "x86-64",
"model": "AMD Opteron", "model": "AMD Opteron",
"other_description": "", "other_description": "AMD Opteron(tm) Processor 250",
"vendor": "AMD", "vendor": "AMD",
"version": "250" "version": 250
"sensors": { "sensors": {
"power": { "power": {
...@@ -83,9 +111,12 @@ ...@@ -83,9 +111,12 @@
"storage_devices": [ "storage_devices": [
"device": "sda",
"driver": "mptspi", "driver": "mptspi",
"interface": "SCSI", "interface": "SCSI",
"size": 67986547946.9299 "model": "MAT3073NC",
"rev": 104,
"size": 73543163904
"supported_job_types": { "supported_job_types": {
"bios": {
"chassis": {
"serial": "XG052075175"
"gpu": { "gpu": {
"bridged": false,
"device": "eth0",
"ip": "172.16.49.10", "ip": "172.16.49.10",
"ip6": "fe80::209:3dff:fe11:aae2",
"mac": "00:09:3d:11:aa:e2", "mac": "00:09:3d:11:aa:e2",
"network_address": "sagittaire-10.lyon.grid5000.fr", "network_address": "sagittaire-10.lyon.grid5000.fr",
"device": "bmc",
"driver": "bnx2",
"enabled": true,
"ip": "172.17.49.10",
"mac": "00:09:3d:11:aa:e3",
"management": true,
"mountable": false,
"mounted": false,
"network_address": "sagittaire-10-bmc.lyon.grid5000.fr",
"rate": 1000000000
"instruction_set": "", "clock_speed": 2392000000,
"device": "sda",
"size": 67986547946.9299 "model": "ST373207LC",
"rev": 2,
"size": 73407868928
"bios": {
"chassis": {
"serial": "XG052536163"
"gpu": { "gpu": {
"bridged": false,
"device": "eth0",
"ip": "172.16.49.11", "ip": "172.16.49.11",
"ip6": "fe80::209:3dff:fe12:9e07",
"mac": "00:09:3d:12:9e:07", "mac": "00:09:3d:12:9e:07",
"network_address": "sagittaire-11.lyon.grid5000.fr", "network_address": "sagittaire-11.lyon.grid5000.fr",
"device": "bmc",
"driver": "bnx2",
"enabled": true,
"ip": "172.17.49.11",
"mac": "00:09:3d:12:9e:0f",
"management": true,
"mountable": false,
"mounted": false,
"network_address": "sagittaire-11-bmc.lyon.grid5000.fr",
"rate": 1000000000
"instruction_set": "", "clock_speed": 2390000000,
"device": "sda",
"size": 67986547946.9299 "model": "ST373307LC",
"rev": 8,
"size": 73407868928
"bios": {
"chassis": {
"serial": "XG052423635"
"gpu": { "gpu": {
"bridged": false,
"device": "eth0",
"ip": "172.16.49.12", "ip": "172.16.49.12",
"ip6": "fe80::209:3dff:fe12:3c2c",
"mac": "00:09:3d:12:3c:2c", "mac": "00:09:3d:12:3c:2c",
"network_address": "sagittaire-12.lyon.grid5000.fr", "network_address": "sagittaire-12.lyon.grid5000.fr",
"device": "bmc",
"driver": "bnx2",
"enabled": true,
"ip": "172.17.49.12",
"mac": "00:09:3d:12:3c:2d",
"management": true,
"mountable": false,
"mounted": false,
"network_address": "sagittaire-12-bmc.lyon.grid5000.fr",
"rate": 1000000000
