Commit 26ab4d9d authored by Pascal Morillon's avatar Pascal Morillon
Add usage exemple for conman generator
parent 85f0fb83
...@@ -24,6 +24,7 @@ OptionParser.new do |opts| ...@@ -24,6 +24,7 @@ OptionParser.new do |opts|
opts.separator "" opts.separator ""
opts.separator "Example: ruby conmang5k.rb -s nancy -o /tmp/puppet-repo" opts.separator "Example: ruby conmang5k.rb -s nancy -o /tmp/puppet-repo"
opts.separator "Example: ruby conmang5k.rb -s nancy -o $GPUPPET_PREFIX/repo"
opts.on('-o', '--output-dir dir', String, 'Select the puppet repo path', "Default: " + options[:output_dir]) do |d| opts.on('-o', '--output-dir dir', String, 'Select the puppet repo path', "Default: " + options[:output_dir]) do |d|
options[:output_dir] = d options[:output_dir] = d
