GitLab
Explore
Primary navigation
Search or go to…
R
reference-repository
Manage
Plan
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Model registry
Operate
Environments
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
grid5000
241a55e6
241a55e6
4 years ago
Samir Noir
Downloads
Patches
[gen/wiki] add links for pmem and multi nics on hardware pages
ca35d3d6
1 merge request
!122
Pipeline
#158707
passed
4 years ago
Stage: validate
Stage: generate
Stage: deploy
lib/refrepo/gen/wiki/generators/site_hardware.rb
+8
-4
8 additions, 4 deletions
8 additions
4 deletions
8
4
241a55e6
@@ -80,7 +80,7 @@ class SiteHardwareGenerator < WikiGenerator
cluster_nodes
cluster_nodes
cell_data
'num_processor_model'
cell_data
cell_data
'cores_per_cpu_str'
cell_data
'cores_per_cpu_str'
sort_data
'ram_size'
'pmem_size'
nil?
cell_data
'pmem_size'
PMEM"
sort_data
'ram_size'
'pmem_size'
nil?
cell_data
'pmem_size'
PMEM
'data-sort-value="'
sort_data
'storage_size'
cell_data
'storage'
'data-sort-value="'
sort_data
'storage_size'
cell_data
'storage'
'data-sort-value="'
sort_data
'network_throughput'
cell_data
'used_networks'
'data-sort-value="'
sort_data
cell_data
'used_networks'
site_accelerators
zero?
with_sites
false
cell_data
'accelerators'
site_accelerators
zero?
with_sites
false
cell_data
'accelerators'
@@ -134,7 +134,7 @@ class SiteHardwareGenerator < WikiGenerator
'Model'
h
'model'
'Model'
h
'model'
'Date of arrival'
h
'date'
'Date of arrival'
h
'date'
'CPU'
h
'processor_description'
'CPU'
h
'Memory'
h
'ram_size'
h
'pmem_size'
nil?
h
'pmem_size'
PMEM"
'Memory'
h
'ram_size'
h
'pmem_size'
nil?
h
'pmem_size'
PMEM
'Storage'
h
'storage_description'
'Storage'
h
'Network'
h
'network_description'
'Network'
h
@@ -308,7 +308,7 @@ def get_hardware(sites)
sort_by
e
sort_by
e
e
'device'
e
'device'
hard
network_description
map
do
e
hard
network_description
map
with_index
do
e
i
s
e
'count'
\n
s
e
'count'
\n
s
e
'unavailable_for_experiment'
'<span style="color:grey">'
s
e
if
e
'name'
nil?
e
'name'
e
'device'
if
e
'name'
nil?
e
'name'
e
'device'
@@ -328,7 +328,11 @@ def get_hardware(sites)
s
'model: '
e
'model'
s
'model: '
e
'model'
s
'driver: '
e
'driver'
if
e
'driver'
s
'driver: '
e
'driver'
if
e
'driver'
s
' - unavailable for experiment'
if
e
if
e
s
elsif
e
'device'
/eth/
i
zero?
s
' [[Advanced_KaVLAN#A_simple_multi_NICs_example|(multi NICs example)]]'
s
' - no KaVLAN'
if
e
'no_kavlan'
s
' - no KaVLAN'
if
e
'no_kavlan'
s
e
'</span>'
s
e
'</span>'
s
s
This diff is collapsed.
Loading
Save comment
