GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
grid5000
reference-repository
23501e81
23501e81
Jérémie Gaidamour
[dev] Bug fix in hashdiff for pdu arrays
4e19b8f7
generators/input-validators/check-cluster-homogeneity.rb
23501e81
@@ -43,8 +43,15 @@ def cluster_homogeneity(refapi_hash, verbose=false)
pdu
pdu
pdu.port
pdu.port
pdu.uid
pdu.uid
pdu[0]
pdu[1]
supported_job_types.max_walltime
mic.ip
mic.mac
status
ignore_netkeys
eos
ignore_netkeys
eos
@@ -107,15 +114,37 @@ eos
#next if node_uid != 'graphene-2'
diffs
HashDiff
diff
refnode
node
diffs
HashDiff
diff
refnode
node
# Hack HashDiff output for arrays:
#[["-", "pdu[1]", {"uid"=>"graphene-pdu9", "port"=>24}],
# ["-", "pdu[0]", {"uid"=>"graphene-pdu9", "port"=>23}],
# ["+", "pdu[0]", {"uid"=>"graphene-pdu9", "port"=>21}],
# ["+", "pdu[1]", {"uid"=>"graphene-pdu9", "port"=>22}]]
# => should be something like this:
# [["~", "pdu[0]", {"uid"=>"graphene-pdu9", "port"=>23}, {"uid"=>"graphene-pdu9", "port"=>22},
# ["~", "pdu[1]", {"uid"=>"graphene-pdu9", "port"=>24}, {"uid"=>"graphene-pdu9", "port"=>23}}
d
diffs
select
x
x
group_by
x
x
d
each
k
v
d
k
v
group_by
x
x
d
each
k
v
if
v
key?
v
key?
#puts "Warning: #{node_uid}: convert +/- -> ~ for #{k}"
diffs
delete
k
v
diffs
delete
k
v
diffs
k
v
v
# end of hack
# Remove keys that are specific to each nodes (ip, mac etc.)
diffs
clone
each
diff
diffs
clone
each
diff
diffs
delete
diff
if
diff
ignore_keys
include?
diff
diffs
delete
diff
if
diff
ignore_keys
include?
diff
if
verbose
diffs
empty?
if
verbose
diffs
empty?
puts
"Differences between
refnode_uid
node_uid
puts
refnode_uid
node_uid
pp
diffs
pp
diffs
count
site_uid
cluster_uid
diffs
size
count
site_uid
cluster_uid
diffs
size
