Commit 1c2e3f38 authored by Vidal WATAT's avatar Vidal WATAT
[sophia] - correct kind for edgeiron switch -
parent e40b26ac
"backplane_bps": null,
"channels": { "channels": {
"naming_pattern": "Po%CHANNELID%" "naming_pattern": "Po%CHANNELID%"
"kind": "router", "kind": "switch",
"linecards": [ "linecards": [
"kind": "router", "kind": "router",
...@@ -11,7 +12,7 @@ ...@@ -11,7 +12,7 @@
"naming_pattern": "ethernet%LINECARD%/%PORT%", "naming_pattern": "ethernet%LINECARD%/%PORT%",
"ports": [ "ports": [
edgeiron: edgeiron:
model: Foundry model: Foundry
kind: router kind: switch
site: sophia site: sophia
snmp_community: public snmp_community: public
weathermap: weathermap:
...@@ -15,7 +15,7 @@ gw-sophia: ...@@ -15,7 +15,7 @@ gw-sophia:
linecards: linecards:
2: 2:
naming_pattern: "ethernet%LINECARD%/%PORT%" naming_pattern: "ethernet%LINECARD%/%PORT%"
rate: 10000000000 rate: 10000000000
ports: ports:
1: 1:
