Commit 185684b2 authored by MICHON Nicolas's avatar MICHON Nicolas
[dev] wiki oar_properties: added mic, removed cpucount and minor update
parent 8d56e600
# coding: utf-8
require 'pp' require 'pp'
require_relative '../lib/input_loader' require_relative '../lib/input_loader'
...@@ -74,9 +75,9 @@ class OarPropertiesGenerator < WikiGenerator ...@@ -74,9 +75,9 @@ class OarPropertiesGenerator < WikiGenerator
"cpufreq" => { "cpufreq" => {
"description" => "The frequency in GHz of resource's CPU" "description" => "The frequency in GHz of resource's CPU"
"cpucount" => { #Unused ? # "cpucount" => { #Unused ?
"description" => "The number of CPUs" # "description" => "The number of CPUs"
"eth_count" => { "eth_count" => {
"description" => "The number of Ethernet interface the node has" "description" => "The number of Ethernet interface the node has"
...@@ -121,6 +122,10 @@ class OarPropertiesGenerator < WikiGenerator ...@@ -121,6 +122,10 @@ class OarPropertiesGenerator < WikiGenerator
"wattmeter" => { "wattmeter" => {
"description" => "The type of wattmeter available" "description" => "The type of wattmeter available"
"mic" => {
"description" => "Intel many integrated core architecture support",
"value_type" => "Boolean"
...@@ -128,7 +133,7 @@ class OarPropertiesGenerator < WikiGenerator ...@@ -128,7 +133,7 @@ class OarPropertiesGenerator < WikiGenerator
@@categories = { @@categories = {
"Job-related properties" => ["besteffort", "deploy", "production", "cluster_priority", "max_walltime"], "Job-related properties" => ["besteffort", "deploy", "production", "cluster_priority", "max_walltime"],
"Hierarchy" => ["cluster", "cpu", "core", "host", "network_address", "ip", "switch"], "Hierarchy" => ["cluster", "cpu", "core", "host", "network_address", "ip", "switch"],
"Hardware" => ["gpu", "gpu_count", "memnode", "memcore", "memcpu", "disktype", "myri_rate", "myri_count", "myri", "ib_rate", "ib_count", "ib", "eth_rate", "eth_count", "cpucount", "cpufreq", "cputype", "cpucore", "cpuarch", "virtual"], "Hardware" => ["gpu", "gpu_count", "memnode", "memcore", "memcpu", "disktype", "myri_rate", "myri_count", "myri", "ib_rate", "ib_count", "ib", "eth_rate", "eth_count", "cpufreq", "cputype", "cpucore", "cpuarch", "virtual", "mic"],
"Miscellaneous" => ["wattmeter", "nodemodel"] "Miscellaneous" => ["wattmeter", "nodemodel"]
...@@ -191,8 +196,12 @@ class OarPropertiesGenerator < WikiGenerator ...@@ -191,8 +196,12 @@ class OarPropertiesGenerator < WikiGenerator
oar_properties.each { |prop, prop_hash| oar_properties.each { |prop, prop_hash|
#Limit possible values to 20 elements if (prop_hash["values"].length > 20)
#Limit possible values to 20 elements and mark the list as truncated
prop_hash["values"].slice!(0...-20) prop_hash["values"].slice!(0...-20)
prop_hash["values"].push("...")
@@properties[prop]["possible_values"] ||= prop_hash["values"].join(", ")
@generated_content = "Properties on resources managed by OAR allow users to select them according to their experiment's characteristics." + MW::LINE_FEED @generated_content = "Properties on resources managed by OAR allow users to select them according to their experiment's characteristics." + MW::LINE_FEED
...@@ -206,8 +215,7 @@ class OarPropertiesGenerator < WikiGenerator ...@@ -206,8 +215,7 @@ class OarPropertiesGenerator < WikiGenerator
@generated_content += @@properties[property]["description"] + MW::LINE_FEED @generated_content += @@properties[property]["description"] + MW::LINE_FEED
value_type = get_value_type(property, values) value_type = get_value_type(property, values)
@generated_content += MW::LIST_ITEM + " Value type: " + MW::code(value_type) + MW::LINE_FEED @generated_content += MW::LIST_ITEM + " Value type: " + MW::code(value_type) + MW::LINE_FEED
possible_values = @@properties[property]["possible_values"] || values.join(", ") @generated_content += MW::LIST_ITEM + " Possible values: " + MW::code(@@properties[property]["possible_values"]) + MW::LINE_FEED
@generated_content += MW::LIST_ITEM + " Possible values: " + MW::code(possible_values) + MW::LINE_FEED
end end
