Commit 13db801d authored by Emile Morel's avatar Emile Morel
[nancy] change graphene-28 eth mac addr
parent 07ce0dac
...@@ -29,8 +29,8 @@ ...@@ -29,8 +29,8 @@
"enabled": true, "enabled": true,
"interface": "Ethernet", "interface": "Ethernet",
"ip": "172.16.64.28", "ip": "172.16.64.28",
"ip6": "fe80::2e0:81ff:fed5:65c", "ip6": "fe80::2e0:81ff:fed5:07f0",
"mac": "00:e0:81:d5:06:5c", "mac": "00:e0:81:d5:07:f0",
"management": false, "management": false,
"mountable": true, "mountable": true,
"mounted": true, "mounted": true,
...@@ -47,7 +47,7 @@ ...@@ -47,7 +47,7 @@
"driver": "e1000e", "driver": "e1000e",
"enabled": false, "enabled": false,
"mac": "00:e0:81:d5:06:5d", "mac": "00:e0:81:d5:07:f1",
"mountable": false, "mountable": false,
"mounted": false, "mounted": false,
...@@ -61,7 +61,7 @@ ...@@ -61,7 +61,7 @@
"mac": "00:e0:81:d5:06:5e", "mac": "00:e0:81:d5:07:f2",
...@@ -2541,8 +2541,8 @@ graphene-28: ...@@ -2541,8 +2541,8 @@ graphene-28:
eth0: eth0:
mounted: true mounted: true
rate: 1000000000 rate: 1000000000
mac: 00:e0:81:d5:06:5c mac: 00:e0:81:d5:07:f0
ip6: fe80::2e0:81ff:fed5:65c ip6: fe80::2e0:81ff:fed5:07f0
management: false management: false
enabled: true enabled: true
interface: Ethernet interface: Ethernet
...@@ -2552,7 +2552,7 @@ graphene-28: ...@@ -2552,7 +2552,7 @@ graphene-28:
eth1: eth1:
mounted: false mounted: false
rate: 100000000 rate: 100000000
mac: 00:e0:81:d5:06:5d mac: 00:e0:81:d5:07:f1
enabled: false enabled: false
...@@ -2560,7 +2560,7 @@ graphene-28: ...@@ -2560,7 +2560,7 @@ graphene-28:
mountable: false mountable: false
eth2: eth2:
mac: 00:e0:81:d5:06:5e mac: 00:e0:81:d5:07:f2
