add a spec test for cluster with 'round-robin' cpuset distributions
55f0982f
- lib/refrepo/gen/oar-properties.rb 3 additions, 3 deletionslib/refrepo/gen/oar-properties.rb
- spec/oar_properties_spec.rb 213 additions, 0 deletionsspec/oar_properties_spec.rb
- spec/stub_oar_properties/load_data_hierarchy_stubbed_data.json 2 additions, 2 deletions...stub_oar_properties/load_data_hierarchy_stubbed_data.json
- spec/stub_oar_properties/load_data_hierarchy_stubbed_data_round_robin_cpusets.json 815 additions, 0 deletions...load_data_hierarchy_stubbed_data_round_robin_cpusets.json
- spec/stub_oar_properties/load_data_hierarchy_stubbed_data_with_disk.json 4 additions, 4 deletions...roperties/load_data_hierarchy_stubbed_data_with_disk.json
- spec/stub_oar_properties/load_data_hierarchy_stubbed_data_without_gpu.json 6 additions, 6 deletions...perties/load_data_hierarchy_stubbed_data_without_gpu.json
Loading
