Commit 00baec16 authored by Pascal Morillon's avatar Pascal Morillon
Merge branch 'sophia'
parents d5fe58a2 d7daa910
...@@ -52,26 +52,41 @@ site :sophia do |site_uid| ...@@ -52,26 +52,41 @@ site :sophia do |site_uid|
:driver => "amd74xx" :driver => "amd74xx"
network_adapters [{ network_adapters [{
:interface => 'Myri-2000',
:rate => 2.G,
:enabled => true,
:switch => "cisco1",
:network_address => "#{node_uid}.#{site_uid}.grid5000.fr",
:ip => dns_lookup("#{node_uid}.#{site_uid}.grid5000.fr"),
:vendor => 'Myrinet',
:version => "M3F-PCIXF-2"
:interface => 'Ethernet', :interface => 'Ethernet',
:rate => 1.G, :rate => 1.G,
:enabled => true, :enabled => true,
:driver => "tg3" :mountable => true,
:mounted => true,
:device => "eth0",
:driver => "tg3",
:vendor => 'Broadcom Corporation',
:version => 'NetXtreme BCM5704',
:enabled => false, :enabled => false,
:driver => "tg3" :mountable => false,
:mounted => false,
:driver => "tg3",
:interface => 'Myrinet',
:rate => 2.G,
:enabled => true,
:mountable => true,
:mounted => true,
:device => "myri0",
:network_address => "#{node_uid}-myri0.#{site_uid}.grid5000.fr",
:ip => dns_lookup("#{node_uid}-myri0.#{site_uid}.grid5000.fr"),
:version => "M3F-PCIXF-2",
:driver => 'mx'
end end
end end
...@@ -122,38 +137,61 @@ site :sophia do |site_uid| ...@@ -122,38 +137,61 @@ site :sophia do |site_uid|
:raid => "0" :raid => "0"
:rate => 2.G,
:enabled => true,
:switch => "edgeiron48gs",
:driver => "e1000" :mountable => true,
:mounted => true,
:device => "eth0",
:driver => "e1000",
:vendor => 'Intel Corporation',
:version => '82546EB'
:driver => "e1000" :mountable => false,
:mounted => false,
:driver => "e1000",
:mounted => false,
:driver => "e1000",
:mounted => false,
:driver => "e1000",
:rate => 2.G,
:enabled => true,
:mountable => true,
:mounted => true,
:device => "myri0",
:driver => 'mx'
end end
end end
...@@ -199,7 +237,10 @@ site :sophia do |site_uid| ...@@ -199,7 +237,10 @@ site :sophia do |site_uid|
:mountable => true,
:mounted => true,
:device => "eth0",
:switch => "fastiron", :switch => "fastiron",
:network_address => "#{node_uid}.#{site_uid}.grid5000.fr", :network_address => "#{node_uid}.#{site_uid}.grid5000.fr",
:ip => dns_lookup("#{node_uid}.#{site_uid}.grid5000.fr"), :ip => dns_lookup("#{node_uid}.#{site_uid}.grid5000.fr"),
...@@ -211,6 +252,8 @@ site :sophia do |site_uid| ...@@ -211,6 +252,8 @@ site :sophia do |site_uid|
:mounted => false,
:vendor => "NVIDIA", :vendor => "NVIDIA",
:version => "MCP55 Pro", :version => "MCP55 Pro",
:driver => "forcedeth" :driver => "forcedeth"
...@@ -219,6 +262,8 @@ site :sophia do |site_uid| ...@@ -219,6 +262,8 @@ site :sophia do |site_uid|
:mounted => false,
:vendor => "Broadcom", :vendor => "Broadcom",
:version => "BCM5715c", :version => "BCM5715c",
:driver => "tg3" :driver => "tg3"
...@@ -227,6 +272,8 @@ site :sophia do |site_uid| ...@@ -227,6 +272,8 @@ site :sophia do |site_uid|
:mounted => false,
...@@ -276,7 +323,10 @@ site :sophia do |site_uid| ...@@ -276,7 +323,10 @@ site :sophia do |site_uid|
:mountable => true,
:mounted => true,
:device => "eth0",
...@@ -287,10 +337,9 @@ site :sophia do |site_uid| ...@@ -287,10 +337,9 @@ site :sophia do |site_uid|
:switch => "fastiron", :mountable => false,
:network_address => "#{node_uid}.#{site_uid}.grid5000.fr", :mounted => false,
:version => "NetXtremeII BCM5716", :version => "NetXtremeII BCM5716",
:driver => "bnx2" :driver => "bnx2"
