Commit 0026e36e authored by Pierre Neyron's avatar Pierre Neyron :bicyclist:
[wiki] factorize disk size computation + homogenize size
But should be GiB TiB no GB TB...
parent 8573c4fb
Pipeline #52850 passed
...@@ -260,14 +260,6 @@ class G5KHardwareGenerator < WikiGenerator ...@@ -260,14 +260,6 @@ class G5KHardwareGenerator < WikiGenerator
date date
end end
def storage_size_to_text(s)
if s > 1000*1000*1000*1000 # 1 TB
return sprintf("%.1f", s.to_f/(1000*1000*1000*1000)) + ' TB'
else
return sprintf("%d", s/(1000*1000*1000)) + ' GB'
def generate_storage def generate_storage
table_columns = ["Site", "Cluster", "Number of nodes", "Main disk", "Additional HDDs", "Additional SSDs", "[[Disk_reservation|Disk reservation]]"] table_columns = ["Site", "Cluster", "Number of nodes", "Main disk", "Additional HDDs", "Additional SSDs", "[[Disk_reservation|Disk reservation]]"]
table_data = [] table_data = []
...@@ -282,19 +274,19 @@ class G5KHardwareGenerator < WikiGenerator ...@@ -282,19 +274,19 @@ class G5KHardwareGenerator < WikiGenerator
sd = node_hash['storage_devices'] sd = node_hash['storage_devices']
reservable_disks = sd.to_a.select{ |v| v[1]['reservation'] == true }.count > 0 reservable_disks = sd.to_a.select{ |v| v[1]['reservation'] == true }.count > 0
maindisk = sd.to_a.select { |v| v[0] == 'sda' }.first[1] maindisk = sd.to_a.select { |v| v[0] == 'sda' }.first[1]
maindisk_t = maindisk['storage'] + ' ' + storage_size_to_text(maindisk['size']) maindisk_t = maindisk['storage'] + ' ' + G5K.get_size(maindisk['size'])
other = sd.to_a.select { |d| d[0] != 'sda' } other = sd.to_a.select { |d| d[0] != 'sda' }
hdds = other.select { |d| d[1]['storage'] == 'HDD' } hdds = other.select { |d| d[1]['storage'] == 'HDD' }
if hdds.count == 0 if hdds.count == 0
hdd_t = "0" hdd_t = "0"
else else
hdd_t = hdds.count.to_s + " (" + hdds.map { |d| storage_size_to_text(d[1]['size']) }.join(', ') + ")" hdd_t = hdds.count.to_s + " (" + hdds.map { |d| G5K.get_size(d[1]['size']) }.join(', ') + ")"
end end
ssds = other.select { |d| d[1]['storage'] == 'SSD' } ssds = other.select { |d| d[1]['storage'] == 'SSD' }
if ssds.count == 0 if ssds.count == 0
ssd_t = "0" ssd_t = "0"
else else
ssd_t = ssds.count.to_s + " (" + ssds.map { |d| storage_size_to_text(d[1]['size']) }.join(', ') + ")" ssd_t = ssds.count.to_s + " (" + ssds.map { |d| G5K.get_size(d[1]['size']) }.join(', ') + ")"
end end
queues = cluster_hash['queues'] - ['admin', 'default'] queues = cluster_hash['queues'] - ['admin', 'default']
queue_t = (queues.nil? || (queues.empty? ? '' : "_.28" + queues[0].gsub(' ', '_') + ' queue.29')) queue_t = (queues.nil? || (queues.empty? ? '' : "_.28" + queues[0].gsub(' ', '_') + ' queue.29'))
