Commit bde67c14 authored by Samir Noir's avatar Samir Noir 🧀
Better performance for resources' versions listing
parent 8041022f
Pipeline #310332 passed with stages
in 19 minutes and 56 seconds
...@@ -224,7 +224,11 @@ class VersionsController < ApplicationController ...@@ -224,7 +224,11 @@ class VersionsController < ApplicationController
protected protected
def resource_path def resource_path
@resource_path ||= params[:resource].gsub(%r{/?platforms}, '') if params[:resource]
else
end end
def metadata_for_commit(commit, resource_path) def metadata_for_commit(commit, resource_path)
...@@ -302,17 +302,10 @@ module Grid5000 ...@@ -302,17 +302,10 @@ module Grid5000
if oid if oid
walker = Rugged::Walker.new(instance) walker = Rugged::Walker.new(instance)
walker.sorting(Rugged::SORT_DATE)
walker.push(oid) walker.push(oid)
commits = walker.select do |commit| commits = walker.select do |commit|
commit.diff(paths: [path]).size > 0 entry_changed?(commit, path)
if commits.empty?
commit.diff(paths: [path + '.json']).size > 0
end end
end end
...@@ -322,6 +315,41 @@ module Grid5000 ...@@ -322,6 +315,41 @@ module Grid5000
'items' => commits.slice(offset, limit) 'items' => commits.slice(offset, limit)
end end
# Implementing git log behavior with Walker from libgit2 can results in slow
# responses. Filtering on path for each commit is time consuming.
# Adapted from: https://github.com/libgit2/rugged/issues/343
def entry_changed?(commit, path)
parent = commit.parents[0]
entry = commit.tree.path(path) rescue nil
# if at a root commit, consider it changed if we have this file;
# i.e. if we added it in the initial commit
if !parent
return entry != nil
parent_entry = begin
parent.tree.path(path)
rescue Rugged::TreeError
begin
parent.tree.path(path + '.json')
nil
# does exist in either, no change
if !entry && !parent_entry
false
# only in one of them, change
elsif !entry || !parent_entry
true
# otherwise it's changed if their ids arent' the same
else
entry[:oid] != parent_entry[:oid]
end end
module Errors module Errors
