Commit 7bac3d00 authored by Samir Noir's avatar Samir Noir 🧀
Release v3.9.1
parent 17b90cbe
Pipeline #157565 passed with stages
in 20 minutes and 9 seconds
g5k-api (3.9.1) unstable; urgency=low
* 17b90cb Return 404 when an ui template cannot be found
* 41b3560 Fix the message sent to client when a http request to an upstream fail
* ce79581 Replace Grit by Rugged libgit2 binding for accessing git repository
* 7add77f Remove remaining notifications usage
-- Samir Noir <samir.noir@inria.fr> Wed, 15 Jul 2020 18:29:25 +0200
g5k-api (3.9.0) unstable; urgency=low g5k-api (3.9.0) unstable; urgency=low
* e512131 No headers are required when getting environments from Kadeploy * e512131 No headers are required when getting environments from Kadeploy
...@@ -13,5 +13,5 @@ ...@@ -13,5 +13,5 @@
# limitations under the License. # limitations under the License.
module Grid5000 module Grid5000
VERSION = "3.9.0" VERSION = "3.9.1"
end end
