Commit 778d0f3a authored by MARGERY David's avatar MARGERY David Committed by Lucas Nussbaum
Commit version 3.5.4
parent e4dd9fad
g5k-api (3.5.4-1) jessie; urgency=low
* a29423b Change query to increase performance of requests as per bug #7970
-- David Margery <> Sat, 01 Apr 2017 12:53:45 +0000
g5k-api (3.5.3-1) jessie; urgency=low g5k-api (3.5.3-1) jessie; urgency=low
* 600b3af Modified the mechanism for URI construction - for test & development environments. Added spec tests also. * 600b3af Modified the mechanism for URI construction - for test & development environments. Added spec tests also.
...@@ -13,5 +13,5 @@ ...@@ -13,5 +13,5 @@
# limitations under the License. # limitations under the License.
module Grid5000 module Grid5000
VERSION = "3.5.3" # patch upgrade after correction of bug ref 5856, 5912, 5941 VERSION = "3.5.4" # patch upgrade after correction of bug ref 5856, 5912, 5941
end end
Supports Markdown
