Commit 73da0855 authored by Samir Noir's avatar Samir Noir 🧀
Set max_retries to 0 instead of 1 (default) when doing http requests
By default, Net::HTTP perform a retry in some case (for example when a
ReadTimeout occures).
parent 5033a9e2
...@@ -101,6 +101,7 @@ module Grid5000 ...@@ -101,6 +101,7 @@ module Grid5000
http = Net::HTTP.new(uri.host, uri.port) http = Net::HTTP.new(uri.host, uri.port)
http.read_timeout = timeout || 5 http.read_timeout = timeout || 5
http.use_ssl = true if uri.scheme == 'https' http.use_ssl = true if uri.scheme == 'https'
http.max_retries = 0
if tls_options && !tls_options.empty? if tls_options && !tls_options.empty?
http.cert = OpenSSL::X509::Certificate.new(File.read(tls_options[:cert_chain_file])) http.cert = OpenSSL::X509::Certificate.new(File.read(tls_options[:cert_chain_file]))
Supports Markdown
