Commit 307eecf3 authored by MARGERY David's avatar MARGERY David
Commit version 3.5.2
parent 6e314aa2
g5k-api (3.5.2-1) jessie; urgency=low
* 6e314aa [Vagrant] use a better condition de control the bundle install run
* 2ab40a7 fixes #7285 : remove reliance on availability of smt_size to count the number of cores
* 5daa16b Add a precaution against variable header length due to different locales (add missing part of fix)
* c4a1192 Add a precaution against variable header length due to different locales
* 7dbfba3 [ui] allow quick start to select on queues the resources are available on
* abbc568 [Vagrant] Change the proxy rules so as to cover most cases
* 4a13978 [ui] change the behaviour of the filtering mechanism so that filters of different facets intersect rather that add
* baf10dc [ui] use the internal API to get a list of registrere kadeploy environments
* 9ee3fe7 [packaging] Add description to the debian packaging task
-- David Margery <> Thu, 08 Sep 2016 13:51:10 +0000
g5k-api (3.5.1-1) jessie; urgency=low g5k-api (3.5.1-1) jessie; urgency=low
* 6809a80 [Javascript] Keep the vendorized exhibit version in the repository * 6809a80 [Javascript] Keep the vendorized exhibit version in the repository
...@@ -13,5 +13,5 @@ ...@@ -13,5 +13,5 @@
# limitations under the License. # limitations under the License.
module Grid5000 module Grid5000
VERSION = "3.5.1" # patch upgrade after correction of bug ref 5856, 5912, 5941 VERSION = "3.5.2" # patch upgrade after correction of bug ref 5856, 5912, 5941
end end
Supports Markdown
