Commit 84bd1cdf authored by Bruno Guillaume's avatar Bruno Guillaume
* Type of Graph.node_matching changed!
New ordering of graph nodes (two subsets)
parent c51a331f
...@@ -382,11 +382,14 @@ module P_fs = struct ...@@ -382,11 +382,14 @@ module P_fs = struct
let check_position ?param position t = let check_position ?param position t =
try try
match List.assoc "position" t with match (List.assoc "position" t, position) with
| {P_feature.cst=P_feature.Equal pos_list; in_param=[]} -> List.mem (Float position) pos_list | ({P_feature.cst=P_feature.Equal pos_list; in_param=[]}, Some p) -> List.mem (Float p) pos_list
| {P_feature.cst=P_feature.Different pos_list; in_param=[]} -> not (List.mem (Float position) pos_list) | ({P_feature.cst=P_feature.Equal pos_list; in_param=[]}, None) -> false
| {P_feature.cst=P_feature.Absent} -> false | ({P_feature.cst=P_feature.Different pos_list; in_param=[]}, Some p) -> not (List.mem (Float p) pos_list)
| _ -> Error.bug "Position can't be parametrized" | ({P_feature.cst=P_feature.Different pos_list; in_param=[]}, None) -> false
| ({P_feature.cst=P_feature.Absent}, Some _) -> false
| ({P_feature.cst=P_feature.Absent}, None) -> true
with Not_found -> true with Not_found -> true
let build ?domain ?pat_vars ast_fs = let build ?domain ?pat_vars ast_fs =
...@@ -97,7 +97,7 @@ module P_fs: sig ...@@ -97,7 +97,7 @@ module P_fs: sig
(** [check_position ?parma position pfs] checks wheter [pfs] is compatible with a node at [position]. (** [check_position ?parma position pfs] checks wheter [pfs] is compatible with a node at [position].
It returns [true] iff [pfs] has no requirement about position ok if the requirement is satisfied. *) It returns [true] iff [pfs] has no requirement about position ok if the requirement is satisfied. *)
val check_position: ?param:Lex_par.t -> float -> t -> bool val check_position: ?param:Lex_par.t -> float option -> t -> bool
exception Fail_unif exception Fail_unif
...@@ -296,8 +296,8 @@ module G_graph = struct ...@@ -296,8 +296,8 @@ module G_graph = struct
let node = Gid_map.find node_id graph.map in let node = Gid_map.find node_id graph.map in
Massoc_gid.exists (fun _ e -> Label_cst.match_ ?domain label_cst e) (G_node.get_next node) Massoc_gid.exists (fun _ e -> Label_cst.match_ ?domain label_cst e) (G_node.get_next node)
let get_annot_info graph = let get_annot_info graph = failwith "Unused function !"
let annot_info = (* let annot_info =
Gid_map.fold Gid_map.fold
(fun _ node acc -> (fun _ node acc ->
match (G_node.get_annot_info node, acc) with match (G_node.get_annot_info node, acc) with
...@@ -307,7 +307,7 @@ module G_graph = struct ...@@ -307,7 +307,7 @@ module G_graph = struct
) graph.map None in ) graph.map None in
match annot_info with match annot_info with
| Some x -> x | Some x -> x
| None -> Error.build "[G_node.get_annot_info] No nodes with annot info" | None -> Error.build "[G_node.get_annot_info] No nodes with annot info" *)
let map_add_edge_opt map id_src label id_tar = let map_add_edge_opt map id_src label id_tar =
...@@ -350,7 +350,7 @@ module G_graph = struct ...@@ -350,7 +350,7 @@ module G_graph = struct
else else
let (new_tail, table) = loop (node_id :: already_bound) (index+1) (Some index) tail in let (new_tail, table) = loop (node_id :: already_bound) (index+1) (Some index) tail in
let succ = if tail = [] then None else Some (index+1) in let succ = if tail = [] then None else Some (index+1) in
let new_node = G_node.build ?domain ?prec ?succ index (ast_node, loc) in let new_node = G_node.build ?domain ?prec ?succ ~position:(float index) (ast_node, loc) in
Gid_map.add index new_node new_tail, Gid_map.add index new_node new_tail,
(node_id,index)::table (node_id,index)::table
...@@ -529,54 +529,62 @@ module G_graph = struct ...@@ -529,54 +529,62 @@ module G_graph = struct
{ graph with map = new_map } { graph with map = new_map }
let insert ?domain id1 id2 graph = let insert id1 id2 graph =
let node1 = Gid_map.find id1 graph.map in let node1 = Gid_map.find id1 graph.map in
let node2 = Gid_map.find id2 graph.map in let node2 = Gid_map.find id2 graph.map in
let pos1 = G_node.get_position node1 in let new_pos = match (G_node.get_position node1, G_node.get_position node2) with
let pos2 = G_node.get_position node2 in | (G_node.Ordered pos1, G_node.Ordered pos2) -> (pos1 +. pos2) /. 2.
let new_pos= (pos1 +. pos2) /. 2. in | _ -> Error.run "Try to insert into non ordered nodes" in
let new_gid = graph.highest_index + 1 in let new_gid = graph.highest_index + 1 in
let map = graph.map let map = graph.map
|> (Gid_map.add new_gid (G_node.fresh ?domain ~prec:id1 ~succ:id2 new_pos)) |> (Gid_map.add new_gid (G_node.fresh ~prec:id1 ~succ:id2 new_pos))
|> (Gid_map.add id1 (G_node.set_succ new_gid node1)) |> (Gid_map.add id1 (G_node.set_succ new_gid node1))
|> (Gid_map.add id2 (G_node.set_prec new_gid node2)) in |> (Gid_map.add id2 (G_node.set_prec new_gid node2)) in
(new_gid, { graph with map; highest_index = new_gid }) (new_gid, { graph with map; highest_index = new_gid })
let append ?domain id graph = let append id graph =
let node = Gid_map.find id graph.map in let node = Gid_map.find id graph.map in
let pos = G_node.get_position node in let new_pos = match G_node.get_position node with
let new_pos= pos +. 1. in | G_node.Ordered pos -> pos +. 1.
| _ -> Error.run "Try to append into non ordered nodes" in
|> (Gid_map.add new_gid (G_node.fresh ?domain ~prec:id new_pos)) |> (Gid_map.add new_gid (G_node.fresh ~prec:id new_pos))
|> (Gid_map.add id (G_node.set_succ new_gid node)) in |> (Gid_map.add id (G_node.set_succ new_gid node)) in
let prepend ?domain id graph = let prepend id graph =
let new_pos= pos -. 1. in | G_node.Ordered pos -> pos -. 1.
| _ -> Error.run "Try to prepend into non ordered nodes" in
|> (Gid_map.add new_gid (G_node.fresh ?domain ~succ:id new_pos)) |> (Gid_map.add new_gid (G_node.fresh ~succ:id new_pos))
|> (Gid_map.add id (G_node.set_prec new_gid node)) in |> (Gid_map.add id (G_node.set_prec new_gid node)) in
let add_after loc ?domain node_id graph = let add_after node_id graph =
match G_node.get_succ node with match G_node.get_succ node with
| Some gid_succ -> insert ?domain node_id gid_succ graph | Some gid_succ -> insert node_id gid_succ graph
| None -> append ?domain node_id graph | None -> append node_id graph
let add_before loc ?domain node_id graph = let add_before node_id graph =
match G_node.get_prec node with match G_node.get_prec node with
| Some gid_prec -> insert ?domain gid_prec node_id graph | Some gid_prec -> insert gid_prec node_id graph
| None -> prepend ?domain node_id graph | None -> prepend node_id graph
let add_unordered graph =
let map = Gid_map.add new_gid (G_node.fresh_unordered ()) graph.map in
(* move out-edges (which respect cst [labels,neg]) from id_src are moved to out-edges out off node id_tar *) (* move out-edges (which respect cst [labels,neg]) from id_src are moved to out-edges out off node id_tar *)
...@@ -661,7 +669,11 @@ module G_graph = struct ...@@ -661,7 +669,11 @@ module G_graph = struct
(function (function
| Concat_item.Feat (node_gid, "position") -> | Concat_item.Feat (node_gid, "position") ->
let node = Gid_map.find node_gid graph.map in let node = Gid_map.find node_gid graph.map in
sprintf "%g" (G_node.get_position node) begin
| G_node.Ordered p -> sprintf "%g" p
| _ -> Error.run ?loc "Try to read position of an unordered node"
| Concat_item.Feat (node_gid, feat_name) -> | Concat_item.Feat (node_gid, feat_name) ->
(match G_fs.get_string_atom feat_name (G_node.get_fs node) with (match G_fs.get_string_atom feat_name (G_node.get_fs node) with
...@@ -760,7 +772,8 @@ module G_graph = struct ...@@ -760,7 +772,8 @@ module G_graph = struct
(fun (id, node) -> (fun (id, node) ->
let decorated_feat = try List.assoc id deco.G_deco.nodes with Not_found -> ("",[]) in let decorated_feat = try List.assoc id deco.G_deco.nodes with Not_found -> ("",[]) in
let fs = G_node.get_fs node in let fs = G_node.get_fs node in
let dep_fs = G_fs.to_dep ~decorated_feat ~position:(G_node.get_position node) ?filter ?main_feat fs in let pos= match G_node.get_position node with G_node.Ordered x -> Some x | _ -> None in
let dep_fs = G_fs.to_dep ~decorated_feat ?position:pos ?filter ?main_feat fs in
let style = match G_fs.get_string_atom "void" fs with let style = match G_fs.get_string_atom "void" fs with
| Some "y" -> "; forecolor=red; subcolor=red; " | Some "y" -> "; forecolor=red; subcolor=red; "
...@@ -884,7 +897,7 @@ module G_graph = struct ...@@ -884,7 +897,7 @@ module G_graph = struct
let gnode = List.assoc gid snodes in let gnode = List.assoc gid snodes in
if G_node.is_conll_root gnode if G_node.is_conll_root gnode
then 0. then 0.
else G_node.get_position (List.assoc gid snodes) in else G_node.get_float (List.assoc gid snodes) in
(* Warning: [govs_labs] maps [gid]s to [num]s *) (* Warning: [govs_labs] maps [gid]s to [num]s *)
let govs_labs = let govs_labs =
...@@ -137,8 +137,9 @@ module G_graph: sig ...@@ -137,8 +137,9 @@ module G_graph: sig
[graph] is unchanged if the node is not in it. *) [graph] is unchanged if the node is not in it. *)
val del_node: t -> Gid.t -> t val del_node: t -> Gid.t -> t
val add_before: Loc.t -> ?domain:Domain.t -> Gid.t -> t -> (Gid.t * t) val add_before: Gid.t -> t -> (Gid.t * t)
val add_after: Loc.t -> ?domain:Domain.t -> Gid.t -> t -> (Gid.t * t) val add_after: Gid.t -> t -> (Gid.t * t)
val add_unordered: t -> (Gid.t * t)
(** move all in arcs to id_src are moved to in arcs on node id_tar from graph, with all its incoming edges *) (** move all in arcs to id_src are moved to in arcs on node id_tar from graph, with all its incoming edges *)
val shift_in: Loc.t -> ?domain:Domain.t -> Gid.t -> Gid.t -> (Gid.t -> bool) -> Label_cst.t -> t -> t val shift_in: Loc.t -> ?domain:Domain.t -> Gid.t -> Gid.t -> (Gid.t -> bool) -> Label_cst.t -> t -> t
...@@ -20,13 +20,17 @@ open Grew_fs ...@@ -20,13 +20,17 @@ open Grew_fs
module G_node = struct module G_node = struct
type position =
| Ordered of float
| Unordered of int
type t = { type t = {
name: Id.name option; name: Id.name option;
fs: G_fs.t; fs: G_fs.t;
next: G_edge.t Massoc_gid.t; next: G_edge.t Massoc_gid.t;
succ: Gid.t option; succ: Gid.t option;
prec: Gid.t option; prec: Gid.t option;
position: float; position: position;
conll_root: bool; conll_root: bool;
efs: (string * string) list; efs: (string * string) list;
...@@ -38,7 +42,9 @@ module G_node = struct ...@@ -38,7 +42,9 @@ module G_node = struct
let set_next next t = {t with next } let set_next next t = {t with next }
let get_position t = t.position let get_position t = t.position
let set_position position t = { t with position } let set_position p t = { t with position = Ordered p }
let get_float t = match t.position with Ordered p -> p | Unordered i -> float i
let get_prec t = t.prec let get_prec t = t.prec
let get_succ t = t.succ let get_succ t = t.succ
...@@ -53,7 +59,7 @@ module G_node = struct ...@@ -53,7 +59,7 @@ module G_node = struct
| Some n -> n | Some n -> n
| None -> sprintf "_%s_" (Gid.to_string gid) | None -> sprintf "_%s_" (Gid.to_string gid)
let empty = { name=None; fs = G_fs.empty; next = Massoc_gid.empty; succ = None; prec = None; position = -1.; conll_root=false; efs=[] } let empty = { name=None; fs = G_fs.empty; next = Massoc_gid.empty; succ = None; prec = None; position = Unordered 0; conll_root=false; efs=[] }
let is_conll_root t = t.conll_root let is_conll_root t = t.conll_root
...@@ -75,9 +81,13 @@ module G_node = struct ...@@ -75,9 +81,13 @@ module G_node = struct
let get_annot_info t = G_fs.get_annot_info t.fs let get_annot_info t = G_fs.get_annot_info t.fs
let build ?domain ?prec ?succ position (ast_node, loc) = let current_index = ref 0
let fresh_index () = decr current_index; !current_index
let build ?domain ?prec ?succ ?position (ast_node, loc) =
let fs = G_fs.build ?domain ast_node.Ast.fs in let fs = G_fs.build ?domain ast_node.Ast.fs in
{ empty with name=Some ast_node.Ast.node_id; fs; position = float_of_int position; prec; succ } let pos = match position with None -> Unordered (fresh_index ()) | Some p -> Ordered p in
{ empty with name=Some ast_node.Ast.node_id; fs; position = pos; prec; succ }
let float_of_conll_id = function let float_of_conll_id = function
| (i,None) -> float i | (i,None) -> float i
...@@ -87,14 +97,15 @@ module G_node = struct ...@@ -87,14 +97,15 @@ module G_node = struct
let of_conll ?loc ?prec ?succ ?domain line = let of_conll ?loc ?prec ?succ ?domain line =
if line = Conll.root if line = Conll.root
then { empty with conll_root=true; succ} then { empty with conll_root=true; succ}
else { empty with fs = G_fs.of_conll ?loc ?domain line; position = float_of_conll_id line.Conll.id; prec; succ; efs=line.Conll.efs } else { empty with fs = G_fs.of_conll ?loc ?domain line; position = Ordered (float_of_conll_id line.Conll.id); prec; succ; efs=line.Conll.efs }
let pst_leaf ?loc ?domain phon position = let pst_leaf ?loc ?domain phon position =
{ empty with fs = G_fs.pst_leaf ?loc ?domain phon; position = float position } { empty with fs = G_fs.pst_leaf ?loc ?domain phon; position = Ordered (float position) }
let pst_node ?loc ?domain cat position = let pst_node ?loc ?domain cat position =
{ empty with fs = G_fs.pst_node ?loc ?domain cat; position = float position } { empty with fs = G_fs.pst_node ?loc ?domain cat; position = Ordered (float position) } (* TODO : change to Unordered *)
let fresh ?domain ?prec ?succ position = { empty with position; prec; succ } let fresh ?prec ?succ pos = { empty with position = Ordered pos; prec; succ }
let fresh_unordered () = { empty with position = Unordered (fresh_index ())}
let remove (id_tar : Gid.t) label t = {t with next = Massoc_gid.remove id_tar label t.next} let remove (id_tar : Gid.t) label t = {t with next = Massoc_gid.remove id_tar label t.next}
...@@ -169,9 +180,12 @@ module P_node = struct ...@@ -169,9 +180,12 @@ module P_node = struct
let match_ ?param p_node g_node = let match_ ?param p_node g_node =
(* (match param with None -> printf "<None>" | Some p -> printf "<Some>"; Lex_par.dump p); *) (* (match param with None -> printf "<None>" | Some p -> printf "<Some>"; Lex_par.dump p); *)
if P_fs.check_position ?param (G_node.get_position g_node) p_node.fs match G_node.get_position g_node with
then P_fs.match_ ?param p_node.fs (G_node.get_fs g_node) | G_node.Unordered _ -> None
else raise P_fs.Fail | G_node.Ordered p ->
if P_fs.check_position ?param (Some p) p_node.fs
let compare_pos t1 t2 = Pervasives.compare t1.loc t2.loc let compare_pos t1 t2 = Pervasives.compare t1.loc t2.loc
end (* module P_node *) end (* module P_node *)
...@@ -19,6 +19,11 @@ open Grew_ast ...@@ -19,6 +19,11 @@ open Grew_ast
module G_node: sig module G_node: sig
type position =
| Ordered of float
| Unordered of int
type t type t
val empty: t val empty: t
...@@ -40,6 +45,10 @@ module G_node: sig ...@@ -40,6 +45,10 @@ module G_node: sig
val set_fs: G_fs.t -> t -> t val set_fs: G_fs.t -> t -> t
val set_position: float -> t -> t val set_position: float -> t -> t
val get_position: t -> position
val get_float: t -> float
val set_next: G_edge.t Massoc_gid.t -> t -> t val set_next: G_edge.t Massoc_gid.t -> t -> t
val get_name: Gid.t -> t -> string val get_name: Gid.t -> t -> string
...@@ -57,14 +66,16 @@ module G_node: sig ...@@ -57,14 +66,16 @@ module G_node: sig
val rm_out_edges: t -> t val rm_out_edges: t -> t
val add_edge: G_edge.t -> Gid.t -> t -> t option val add_edge: G_edge.t -> Gid.t -> t -> t option
val build: ?domain:Domain.t -> ?prec:Gid.t -> ?succ:Gid.t -> int -> Ast.node -> t
val build: ?domain:Domain.t -> ?prec:Gid.t -> ?succ:Gid.t -> ?position:float -> Ast.node -> t
val of_conll: ?loc:Loc.t -> ?prec:Gid.t -> ?succ:Gid.t -> ?domain:Domain.t -> Conll.line -> t val of_conll: ?loc:Loc.t -> ?prec:Gid.t -> ?succ:Gid.t -> ?domain:Domain.t -> Conll.line -> t
val pst_leaf: ?loc:Loc.t -> ?domain:Domain.t -> string -> int -> t val pst_leaf: ?loc:Loc.t -> ?domain:Domain.t -> string -> int -> t
val pst_node: ?loc:Loc.t -> ?domain:Domain.t -> string -> int -> t val pst_node: ?loc:Loc.t -> ?domain:Domain.t -> string -> int -> t
val fresh: ?domain:Domain.t -> ?prec:Gid.t -> ?succ:Gid.t -> float -> t val fresh: ?prec:Gid.t -> ?succ:Gid.t -> float -> t
val fresh_unordered: unit -> t
val get_position: t -> float
val position_comp: t -> t -> int val position_comp: t -> t -> int
...@@ -594,7 +594,7 @@ module Rule = struct ...@@ -594,7 +594,7 @@ module Rule = struct
(fun pid gid acc -> (fun pid gid acc ->
let pnode = P_graph.find pid (fst pattern).graph in let pnode = P_graph.find pid (fst pattern).graph in
let gnode = G_graph.find gid graph in let gnode = G_graph.find gid graph in
(P_node.get_name pnode, int_of_float (G_node.get_position gnode)) :: acc (P_node.get_name pnode, G_node.get_float gnode) :: acc
) n_match [] ) n_match []
let empty_matching param = { n_match = Pid_map.empty; e_match = []; m_param = param;} let empty_matching param = { n_match = Pid_map.empty; e_match = []; m_param = param;}
...@@ -684,10 +684,20 @@ module Rule = struct ...@@ -684,10 +684,20 @@ module Rule = struct
let apply_cst ?domain graph matching cst = let apply_cst ?domain graph matching cst =
let get_node pid = G_graph.find (Pid_map.find pid matching.n_match) graph in let get_node pid = G_graph.find (Pid_map.find pid matching.n_match) graph in
let get_string_feat pid = function let get_string_feat pid = function
| "position" -> Some (sprintf "%g" (G_node.get_position (get_node pid))) | "position" ->
begin
match G_node.get_position (get_node pid) with
| G_node.Ordered f -> Some (sprintf "%g" f)
| _ -> Error.run "Cannot read position of an unordered node"
| feat_name -> G_fs.get_string_atom feat_name (G_node.get_fs (get_node pid)) in | feat_name -> G_fs.get_string_atom feat_name (G_node.get_fs (get_node pid)) in
let get_float_feat pid = function let get_float_feat pid = function
| "position" -> Some (G_node.get_position (get_node pid)) | "position" ->
begin
| G_node.Ordered f -> Some f
| feat_name -> G_fs.get_float_feat feat_name (G_node.get_fs (get_node pid)) in | feat_name -> G_fs.get_float_feat feat_name (G_node.get_fs (get_node pid)) in
match cst with match cst with
...@@ -1002,33 +1012,32 @@ module Rule = struct ...@@ -1002,33 +1012,32 @@ module Rule = struct
| Command.NEW_AFTER (created_name,base_cn) -> | Command.NEW_AFTER (created_name,base_cn) ->
let base_gid = node_find base_cn in let base_gid = node_find base_cn in
let (new_gid,new_graph) = G_graph.add_after loc ?domain base_gid instance.Instance.graph in let (new_gid,new_graph) = G_graph.add_after base_gid instance.Instance.graph in
{instance with {instance with
Instance.graph = new_graph; Instance.graph = new_graph;
history = List_.sort_insert (Command.H_NEW_AFTER (created_name,new_gid)) instance.Instance.history; history = List_.sort_insert (Command.H_NEW_AFTER (created_name,base_gid)) instance.Instance.history;
(created_name,new_gid) :: created_nodes (created_name,new_gid) :: created_nodes
| Command.NEW_NODE (created_name) -> | Command.NEW_NODE (created_name) ->
let base_gid = G_graph.get_highest instance.Instance.graph in let (new_gid,new_graph) = G_graph.add_unordered instance.Instance.graph in
history = List_.sort_insert (Command.H_NEW_AFTER (created_name,new_gid)) instance.Instance.history; history = List_.sort_insert (Command.H_NEW_NODE created_name) instance.Instance.history;
| Command.NEW_BEFORE (created_name,base_cn) -> | Command.NEW_BEFORE (created_name,base_cn) ->
let (new_gid,new_graph) = G_graph.add_before loc ?domain base_gid instance.Instance.graph in let (new_gid,new_graph) = G_graph.add_before base_gid instance.Instance.graph in
history = List_.sort_insert (Command.H_NEW_BEFORE (created_name,new_gid)) instance.Instance.history; history = List_.sort_insert (Command.H_NEW_BEFORE (created_name,base_gid)) instance.Instance.history;
...@@ -1317,8 +1326,4 @@ module Rule = struct ...@@ -1317,8 +1326,4 @@ module Rule = struct
Some (apply_rule ?domain instance first_matching_where_all_witout_are_fulfilled rule) Some (apply_rule ?domain instance first_matching_where_all_witout_are_fulfilled rule)
with Not_found -> None with Not_found -> None
end (* module Rule *) end (* module Rule *)
...@@ -109,7 +109,7 @@ module Rule : sig ...@@ -109,7 +109,7 @@ module Rule : sig
val build_pattern: ?domain:Domain.t -> Ast.pattern -> pattern val build_pattern: ?domain:Domain.t -> Ast.pattern -> pattern
(** [node_matching pattern graph matching] return a assoc list (pid_name, gid.position) *) (** [node_matching pattern graph matching] return a assoc list (pid_name, gid.position) *)
val node_matching: pattern -> G_graph.t -> matching -> (string * int) list val node_matching: pattern -> G_graph.t -> matching -> (string * float) list
(** [match_in_graph rule graph] returns the list of matching of the pattern of the rule into the graph *) (** [match_in_graph rule graph] returns the list of matching of the pattern of the rule into the graph *)
val match_in_graph: ?domain:Domain.t -> ?param:Lex_par.t -> pattern -> G_graph.t -> matching list val match_in_graph: ?domain:Domain.t -> ?param:Lex_par.t -> pattern -> G_graph.t -> matching list
...@@ -100,7 +100,7 @@ module Graph : sig ...@@ -100,7 +100,7 @@ module Graph : sig
(** [search_pattern pattern graph] returns the list of the possible matching of [pattern] in [graph] *) (** [search_pattern pattern graph] returns the list of the possible matching of [pattern] in [graph] *)
val search_pattern: ?domain:Domain.t -> Pattern.t -> t -> Matching.t list val search_pattern: ?domain:Domain.t -> Pattern.t -> t -> Matching.t list
val node_matching: Pattern.t -> t -> Matching.t -> (string * int) list val node_matching: Pattern.t -> t -> Matching.t -> (string * float) list
end end
