Commit d7b35afa authored by bguillaum's avatar bguillaum
Fix typo
git-svn-id: svn+ssh://scm.gforge.inria.fr/svn/semagramme/libcaml-grew/trunk@9027 7838e531-6607-4d57-9587-6c381814729c
parent 8dd64f32
...@@ -26,7 +26,7 @@ Version 0.34 (2016/05/10) ...@@ -26,7 +26,7 @@ Version 0.34 (2016/05/10)
--> add_neighbour is now deprecated and new syntax is introduced for nodes creation: --> add_neighbour is now deprecated and new syntax is introduced for nodes creation:
add_node X Create a new node named X wihtout position constraint add_node X Create a new node named X wihtout position constraint
add_node X :> Y Create a new node named X immediatly after Y add_node X :> Y Create a new node named X immediatly after Y
add_node X :> Y Create a new node named X immediatly before Y add_node X :< Y Create a new node named X immediatly before Y
* improve search for a sequence: * improve search for a sequence:
1) search for the sequence with the requested name 1) search for the sequence with the requested name
2) search for the module with the requested name 2) search for the module with the requested name
Supports Markdown
