Commit d747112c authored by bguillaum's avatar bguillaum
add a new type domain in ast/libgrew
git-svn-id: svn+ssh://scm.gforge.inria.fr/svn/semagramme/libcaml-grew/trunk@8838 7838e531-6607-4d57-9587-6c381814729c
parent d1bdd7f2
...@@ -266,16 +266,21 @@ module Ast = struct ...@@ -266,16 +266,21 @@ module Ast = struct
| Modul of modul | Modul of modul
| Includ of (string * Loc.t) | Includ of (string * Loc.t)
type domain = {
feature_domain: Feature_domain.feature_spec list;
label_domain: (string * string list) list;
let empty_domain = { feature_domain=[]; label_domain=[] }
type grs_with_include = { type grs_with_include = {
domain_wi: Feature_domain.feature_spec list; domain_wi: domain;
labels_wi: (string * string list) list; (* the list of global edge labels *)
modules_wi: module_or_include list; modules_wi: module_or_include list;
sequences_wi: sequence list; sequences_wi: sequence list;
type grs = { type grs = {
domain: Feature_domain.feature_spec list; domain: domain;
labels: (string * string list) list;
modules: modul list; modules: modul list;
sequences: sequence list; sequences: sequence list;
...@@ -286,6 +291,6 @@ module Ast = struct ...@@ -286,6 +291,6 @@ module Ast = struct
edges: edge list; edges: edge list;
let empty_grs = { domain = []; labels = []; modules = []; sequences= [] } let empty_grs = { domain = empty_domain; modules = []; sequences= [] }
end (* module Ast *) end (* module Ast *)
...@@ -181,17 +181,20 @@ module Ast : sig ...@@ -181,17 +181,20 @@ module Ast : sig
type domain = {
(* a GRS: graph rewriting system *) (* a GRS: graph rewriting system *)
...@@ -250,11 +250,14 @@ module Grs = struct ...@@ -250,11 +250,14 @@ module Grs = struct
| s::tail -> loop (s.Sequence.name :: already_defined) tail in | s::tail -> loop (s.Sequence.name :: already_defined) tail in
loop [] t.sequences loop [] t.sequences
let domain_build ast_domain =
Domain.build
(Label_domain.build ast_domain.Ast.label_domain)
(Feature_domain.build ast_domain.Ast.feature_domain)
let build filename = let build filename =
let ast = Loader.grs filename in let ast = Loader.grs filename in
let domain = Domain.build let domain = domain_build ast.Ast.domain in
(Label_domain.build ast.Ast.labels)
(Feature_domain.build ast.Ast.domain) in
let modules = List.map (Modul.build domain) ast.Ast.modules in let modules = List.map (Modul.build domain) ast.Ast.modules in
let grs = {domain; sequences = List.map (Sequence.build modules) ast.Ast.sequences; modules; ast; filename} in let grs = {domain; sequences = List.map (Sequence.build modules) ast.Ast.sequences; modules; ast; filename} in
check grs; check grs;
...@@ -92,6 +92,8 @@ module Grs: sig ...@@ -92,6 +92,8 @@ module Grs: sig
val sequence_names: t -> string list val sequence_names: t -> string list
val domain_build: Ast.domain -> Domain.t
(** [build filename] returns the GRS defined in the file [filename] *) (** [build filename] returns the GRS defined in the file [filename] *)
val build: string -> t val build: string -> t
...@@ -405,12 +405,12 @@ module Html_doc = struct ...@@ -405,12 +405,12 @@ module Html_doc = struct
| Feature_domain.Closed (feat_name,values) -> wnl "<b>%s</b> : %s<br/>" feat_name (String.concat " | " values) | Feature_domain.Closed (feat_name,values) -> wnl "<b>%s</b> : %s<br/>" feat_name (String.concat " | " values)
| Feature_domain.Open feat_name -> wnl " <b>%s</b> : *<br/>" feat_name | Feature_domain.Open feat_name -> wnl " <b>%s</b> : *<br/>" feat_name
| Feature_domain.Num feat_name -> wnl " <b>%s</b> : #<br/>" feat_name | Feature_domain.Num feat_name -> wnl " <b>%s</b> : #<br/>" feat_name
) ast.Ast.domain; ) ast.Ast.feature_domain;
wnl " </code>"; wnl " </code>";
wnl " <h6>Labels</h6>"; wnl " <h6>Labels</h6>";
wnl " <code class=\"code\">"; wnl " <code class=\"code\">";
(match ast.Ast.labels with (match ast.Ast.label_domain with
| [] -> wnl "No labels defined!" | [] -> wnl "No labels defined!"
| (l,c)::t -> w "<font color=\"%s\">%s</font>" (of_opt_color c) l; | (l,c)::t -> w "<font color=\"%s\">%s</font>" (of_opt_color c) l;
List.iter List.iter
...@@ -489,7 +489,7 @@ module Html_doc = struct ...@@ -489,7 +489,7 @@ module Html_doc = struct
let domain = Filename.concat output_dir "domain.html" in let domain = Filename.concat output_dir "domain.html" in
let domain_out_ch = open_out domain in let domain_out_ch = open_out domain in
output_string domain_out_ch (domain_text ~corpus ast); output_string domain_out_ch (domain_text ~corpus ast.Ast.domain);
close_out domain_out_ch; close_out domain_out_ch;
(** Modules + rules **) (** Modules + rules **)
...@@ -58,6 +58,17 @@ module Loader = struct ...@@ -58,6 +58,17 @@ module Loader = struct
module_list module_list
with Sys_error msg-> raise (Error (msg, None)) with Sys_error msg-> raise (Error (msg, None))
let domain file =
try
Global.init file;
let in_ch = open_in file in
let lexbuf = Lexing.from_channel in_ch in
let gr = parse_handle file (Grew_parser.domain Grew_lexer.global) lexbuf in
close_in in_ch;
gr
[parse_string file] where [file] is a file following the grew syntax [parse_string file] where [file] is a file following the grew syntax
...@@ -80,7 +91,6 @@ module Loader = struct ...@@ -80,7 +91,6 @@ module Loader = struct
@ (flatten_modules current_file tail) in @ (flatten_modules current_file tail) in
Ast.domain = grs_with_includes.Ast.domain_wi; Ast.domain = grs_with_includes.Ast.domain_wi;
Ast.labels = grs_with_includes.Ast.labels_wi;
Ast.modules = flatten_modules main_file grs_with_includes.Ast.modules_wi; Ast.modules = flatten_modules main_file grs_with_includes.Ast.modules_wi;
Ast.sequences = grs_with_includes.Ast.sequences_wi; Ast.sequences = grs_with_includes.Ast.sequences_wi;
...@@ -17,6 +17,8 @@ module Loader: sig ...@@ -17,6 +17,8 @@ module Loader: sig
(* message and location *) (* message and location *)
exception Error of (string * Loc.t option) exception Error of (string * Loc.t option)
val domain: string -> Ast.domain
val grs: string -> Ast.grs val grs: string -> Ast.grs
val gr: string -> Ast.gr val gr: string -> Ast.gr
...@@ -110,6 +110,7 @@ let localize t = (t,get_loc ()) ...@@ -110,6 +110,7 @@ let localize t = (t,get_loc ())
%start <Grew_ast.Ast.gr> gr %start <Grew_ast.Ast.gr> gr
%start <Grew_ast.Ast.module_or_include list> included %start <Grew_ast.Ast.module_or_include list> included
%start <Grew_ast.Ast.pattern> pattern %start <Grew_ast.Ast.pattern> pattern
%start <Grew_ast.Ast.domain> domain
%left SEMIC %left SEMIC
%left PLUS %left PLUS
...@@ -192,24 +193,33 @@ gr_item: ...@@ -192,24 +193,33 @@ gr_item:
| n1_loc=simple_id_with_loc label=delimited(LTR_EDGE_LEFT,label_ident,LTR_EDGE_RIGHT) n2=simple_id | n1_loc=simple_id_with_loc label=delimited(LTR_EDGE_LEFT,label_ident,LTR_EDGE_RIGHT) n2=simple_id
{ Graph_edge ({Ast.edge_id = None; src=fst n1_loc; edge_label_cst=([label],false); tar=n2}, snd n1_loc) } { Graph_edge ({Ast.edge_id = None; src=fst n1_loc; edge_label_cst=([label],false); tar=n2}, snd n1_loc) }
/* DOMAIN DEFINITION */
domain:
| f=features_group g=labels
{ Ast.feature_domain = f;
label_domain = g;
/* GREW GRAPH REWRITING SYSTEM */ /* GREW GRAPH REWRITING SYSTEM */
grs_with_include: grs_with_include:
| f=features_group g=labels m=module_or_include_list s=option(sequences) EOF | d=domain m=module_or_include_list s=option(sequences) EOF
{ Ast.domain_wi=f; { Ast.domain_wi=d;
labels_wi=g;
modules_wi=m; modules_wi=m;
sequences_wi=match s with Some seq -> seq | None -> []; sequences_wi=match s with Some seq -> seq | None -> [];
grs: grs:
| f=features_group g=labels m=modules s=option(sequences) EOF | d=domain m=modules s=option(sequences) EOF
{ Ast.domain=f; { Ast.domain=d;
labels=g;
modules=m; modules=m;
sequences=match s with Some seq -> seq | None -> []; sequences=match s with Some seq -> seq | None -> [];
This diff is collapsed.
...@@ -37,25 +37,11 @@ exception Run of string * loc option ...@@ -37,25 +37,11 @@ exception Run of string * loc option
exception Bug of string * loc option exception Bug of string * loc option
(** {2 Graph Rewriting System} *) (** {2 Domain} *)
type grs type domain
val empty_grs: grs
(** [load_grs filename] loads a graph rewriting system from [filename]
@raise Parsing_err if libgrew can't parse the file
@raise File_dont_exists if the file doesn't exists *)
val load_grs: string -> grs
(** [get_sequence_names grs] returns the list of sequence names defined in a GRS *) val load_domain: string -> domain
val get_sequence_names: grs -> string list
(** [build_html_doc ?corpus directory grs]
@[corpus] is a flag (default is [false]) for complete html doc with corpus sentence. *)
val build_html_doc: ?corpus:bool -> string -> grs -> unit
val feature_names: grs -> string list option
(** {2 Graph} *) (** {2 Graph} *)
...@@ -64,12 +50,12 @@ val feature_names: grs -> string list option ...@@ -64,12 +50,12 @@ val feature_names: grs -> string list option
File extension should be '.gr' or '.conll'. File extension should be '.gr' or '.conll'.
@raise Parsing_err if libgrew can't parse the file @raise Parsing_err if libgrew can't parse the file
@raise File_dont_exists if the file doesn't exists. *) @raise File_dont_exists if the file doesn't exists. *)
val load_graph: grs -> string -> graph val load_graph: domain -> string -> graph
(** [of_conll filename line_list] *) (** [of_conll filename line_list] *)
val of_conll: grs -> string -> (int * string) list -> graph val of_conll: domain -> string -> (int * string) list -> graph
val of_brown: grs -> ?sentid:string -> string -> graph val of_brown: domain -> ?sentid:string -> string -> graph
val to_sentence: ?main_feat:string -> graph -> string val to_sentence: ?main_feat:string -> graph -> string
...@@ -78,18 +64,38 @@ val to_sentence: ?main_feat:string -> graph -> string ...@@ -78,18 +64,38 @@ val to_sentence: ?main_feat:string -> graph -> string
- the list of node (node is a list of feature (feature is string * string)) - the list of node (node is a list of feature (feature is string * string))
- the list of edge (src, label, tar) where src and tar refers to the position in the node list - the list of edge (src, label, tar) where src and tar refers to the position in the node list
val raw_graph: grs -> graph -> val raw_graph: domain -> graph ->
(string * string) list * (string * string) list *
(string * string) list list * (string * string) list list *
(int * string * int) list (int * string * int) list
val to_dot_graph : grs -> ?main_feat:string -> ?deco:deco -> graph -> string val to_dot_graph : domain -> ?main_feat:string -> ?deco:deco -> graph -> string
val to_dep_graph : domain -> ?filter: string list -> ?main_feat:string -> ?deco:deco -> graph -> string
val to_gr_graph: domain -> graph -> string
val to_dep_graph : grs -> ?filter: string list -> ?main_feat:string -> ?deco:deco -> graph -> string val to_conll_graph: domain -> graph -> string
val to_gr_graph: grs -> graph -> string
val to_conll_graph: grs -> graph -> string (* -------------------------------------------------------------------------------- *)
type grs
val empty_grs: grs
val feature_names: domain -> string list option
(** {2 rew_display: data for the GUI } *) (** {2 rew_display: data for the GUI } *)
...@@ -114,29 +120,29 @@ val num_sol: rewrite_history -> int ...@@ -114,29 +120,29 @@ val num_sol: rewrite_history -> int
val write_stat: string -> rewrite_history -> unit val write_stat: string -> rewrite_history -> unit
val save_gr: grs -> string -> rewrite_history -> unit val save_gr: domain -> string -> rewrite_history -> unit
val save_conll: grs -> string -> rewrite_history -> unit val save_conll: domain -> string -> rewrite_history -> unit
(** [save_full_conll base_name rh] saves one conll_file for each normal form defined in [rh]. (** [save_full_conll base_name rh] saves one conll_file for each normal form defined in [rh].
Output files are named according to [base_name] and a secondary index after "__". Output files are named according to [base_name] and a secondary index after "__".
The number of conll file produced is returned. *) The number of conll file produced is returned. *)
val save_full_conll: grs -> string -> rewrite_history -> int val save_full_conll: domain -> string -> rewrite_history -> int
val save_det_gr: grs -> string -> rewrite_history -> unit val save_det_gr: domain -> string -> rewrite_history -> unit
val save_det_conll: grs -> ?header:string -> string -> rewrite_history -> unit val save_det_conll: domain -> ?header:string -> string -> rewrite_history -> unit
val det_dep_string: grs -> rewrite_history -> string option val det_dep_string: domain -> rewrite_history -> string option
val conll_dep_string: grs -> ?keep_empty_rh:bool -> rewrite_history -> string option val conll_dep_string: domain -> ?keep_empty_rh:bool -> rewrite_history -> string option
val save_index: dirname:string -> base_names: string list -> unit val save_index: dirname:string -> base_names: string list -> unit
val write_annot: grs -> title:string -> string -> string -> (string * rewrite_history) list -> unit val write_annot: domain -> title:string -> string -> string -> (string * rewrite_history) list -> unit
val write_html: val write_html:
grs -> domain ->
?no_init: bool -> ?no_init: bool ->
?out_gr: bool -> ?out_gr: bool ->
?filter: string list -> ?filter: string list ->
...@@ -149,7 +155,7 @@ val write_html: ...@@ -149,7 +155,7 @@ val write_html:
unit unit
val error_html: val error_html:
grs -> domain ->
?no_init:bool -> ?no_init:bool ->
?main_feat:string -> ?main_feat:string ->
?dot: bool -> ?dot: bool ->
...@@ -179,11 +185,11 @@ val html_sentences: title:string -> string -> (bool * string * int * string) lis ...@@ -179,11 +185,11 @@ val html_sentences: title:string -> string -> (bool * string * int * string) lis
type pattern type pattern
type matching type matching
(** [load_pattern filename] returns the pattern describer in the fuile *) (** [load_pattern filename] returns the pattern described in the file *)
val load_pattern: grs -> string -> pattern val load_pattern: domain -> string -> pattern
(** [match_in_graph patern graph] returns the list of the possible matching og [pattern] in [graph] *) (** [match_in_graph pattern graph] returns the list of the possible matching og [pattern] in [graph] *)
val match_in_graph: grs -> pattern -> graph -> matching list val match_in_graph: domain -> pattern -> graph -> matching list
(** [match_deco pattern matching] returns the deco to be used in the graphical representation. (** [match_deco pattern matching] returns the deco to be used in the graphical representation.
WARNING: the function supposes that [matching] was find with the given [pattern]! *) WARNING: the function supposes that [matching] was find with the given [pattern]! *)
