Commit d3207c3a authored by bguillaum's avatar bguillaum
version 0.35.1: adapt to libcaml-conll 0.6
git-svn-id: svn+ssh://scm.gforge.inria.fr/svn/semagramme/libcaml-grew/trunk@9040 7838e531-6607-4d57-9587-6c381814729c
parent aaa40d4e
...@@ -372,18 +372,9 @@ module G_graph = struct ...@@ -372,18 +372,9 @@ module G_graph = struct
| [Str.Text form; Str.Delim pos; Str.Text lemma] -> | [Str.Text form; Str.Delim pos; Str.Text lemma] ->
let pos = String.sub pos 1 ((String.length pos)-2) in let pos = String.sub pos 1 ((String.length pos)-2) in
let feats = match (i,sentid) with let feats = match (i,sentid) with
| (0,Some id) -> [("sentid", id)] | (0,Some id) -> [("sentid", id)]
| _ -> [] in | _ -> [] in
{ Conll.build_line ~id:(i+1) ~form ~lemma ~xpos:pos ~feats ~deps:([(i, "SUC")]) ()
Conll.line_num=0;
id = i+1;
form;
lemma;
upos = "_";
xpos = pos;
feats;
deps = [(i, "SUC")]
| _ -> Error.build "[Graph.of_brown] Cannot parse Brown item >>>%s<<< (expected \"phon/POS/lemma\") in >>>%s<<<" item brown | _ -> Error.build "[Graph.of_brown] Cannot parse Brown item >>>%s<<< (expected \"phon/POS/lemma\") in >>>%s<<<" item brown
) units in ) units in
of_conll domain { Conll.file=None; meta=[]; lines=conll_lines; multiwords=[] } of_conll domain { Conll.file=None; meta=[]; lines=conll_lines; multiwords=[] }
