Commit 971d5500 authored by bguillaum's avatar bguillaum
move from 'int' to 'Gid.t'/'Pid.t'... it compiles
git-svn-id: svn+ssh://scm.gforge.inria.fr/svn/semagramme/libcaml-grew/trunk@7419 7838e531-6607-4d57-9587-6c381814729c
parent c00c6e36
*.cmo
*.cmi
*.o
*.cmx
*.annot
*.a
*.cma
*.cmxa
Makefile
confdefs.h
config.log
config.status
# file generated by the Makefile !
libgrew.mli
......@@ -7,8 +7,8 @@ open Grew_edge
open Grew_fs
module Command = struct
type pid = int (* the int in the pattern *)
type gid = int (* the int in the graph *)
type pid = Pid.t
type gid = Gid.t
type cnode = (* a command node is either: *)
| Pid of pid (* a node identified in the pattern *)
......@@ -3,8 +3,8 @@ open Grew_utils
open Grew_edge
module Command : sig
type pid = Pid.t
type gid = Gid.t
......@@ -10,16 +10,26 @@ open Grew_command
module Deco = struct
module P_deco = struct
type t =
{ nodes: int list;
edges: (int * G_edge.t * int) list;
{ nodes: Pid.t list;
edges: (Pid.t * P_edge.t * Pid.t) list;
let empty = {nodes=[]; edges=[]}
module G_deco = struct
type t =
{ nodes: Gid.t list;
edges: (Gid.t * G_edge.t * Gid.t) list;
module P_graph = struct
......@@ -230,7 +240,7 @@ module G_graph = struct
let table = Array.of_list sorted_ids in
(* the nodes, in the same order *)
let map_without_edges = List_.foldi_left (fun i acc elt -> Gid_map.add i elt acc) Gid_map.empty node_list in
let map_without_edges = List_.foldi_left (fun i acc elt -> Gid_map.add (Gid.Old i) elt acc) Gid_map.empty node_list in
let map =
List.fold_left
......@@ -238,7 +248,7 @@ module G_graph = struct
let i1 = Id.build ~loc ast_edge.Ast.src table in
let i2 = Id.build ~loc ast_edge.Ast.tar table in
let edge = G_edge.build ~locals (ast_edge, loc) in
(match map_add_edge acc i1 edge i2 with
(match map_add_edge acc (Gid.Old i1) edge (Gid.Old i2) with
| Some g -> g
| None -> Error.build "[GRS] [Graph.build] try to build a graph with twice the same edge %s %s"
(G_edge.to_string edge)
......@@ -254,7 +264,7 @@ module G_graph = struct
let nodes =
List.fold_left
(fun acc line ->
Gid_map.add line.Conll.num (G_node.of_conll line) acc)
Gid_map.add (Gid.Old line.Conll.num) (G_node.of_conll line) acc)
Gid_map.empty lines in
let nodes_with_edges =
......@@ -267,12 +277,12 @@ module G_graph = struct
then acc
else
let gov_node =
try Gid_map.find line.Conll.gov acc
try Gid_map.find (Gid.Old line.Conll.gov) acc
with Not_found ->
Error.build ?loc "[G_graph.of_conll] the line refers to unknown gov %d" line.Conll.gov in
match G_node.add_edge (G_edge.make ?loc line.Conll.dep_lab) line.Conll.num gov_node with
match G_node.add_edge (G_edge.make ?loc line.Conll.dep_lab) (Gid.Old line.Conll.num) gov_node with
| None -> acc
| Some new_node -> Gid_map.add line.Conll.gov new_node acc
| Some new_node -> Gid_map.add (Gid.Old line.Conll.gov) new_node acc
) nodes lines in
{map = nodes_with_edges; lub=1+(Gid_map.fold (fun _ _ acc -> acc+1) nodes_with_edges 0)}
......@@ -326,12 +336,15 @@ module G_graph = struct
let add_neighbour loc graph node_id label =
(* index is a new number (higher then lub and uniquely defined by (node_id,label) *)
let index = graph.lub + ((Label.to_int label) * graph.lub) + node_id in
(* let index = graph.lub + ((Label.to_int label) * graph.lub) + node_id in *)
let index = match node_id with
| Gid.Old id -> Gid.New (id, Label.to_int label)
| Gid.New _ -> Error.run ~loc "[Graph.add_neighbour] try to add neighbour node to a neighbour node" in
if Gid_map.mem index graph.map
then Error.run ~loc "[Graph.add_neighbour] try to build twice the \"same\" neighbour node (with label '%s')" (Label.to_string label);
let node = Gid_map.find node_id graph.map in
(* put the new node on the right of its "parent" *)
let new_graph = {graph with map = Gid_map.add index (G_node.build_neighbour node) graph.map} in
......@@ -345,7 +358,7 @@ module G_graph = struct
let shift_in loc graph src_gid tar_gid =
let tar_node = Gid_map.find tar_gid graph.map in
if Massoc.mem_key src_gid (G_node.get_next tar_node)
if Massoc_gid.mem_key src_gid (G_node.get_next tar_node)
then Error.run ~loc "[Graph.shift_in] dependency from tar to src";
let new_map =
......@@ -363,7 +376,7 @@ module G_graph = struct
let src_node = Gid_map.find src_gid graph.map in
if Massoc.mem_key tar_gid (G_node.get_next src_node)
if Massoc_gid.mem_key tar_gid (G_node.get_next src_node)
then Error.run ~loc "[Graph.shift_out] dependency from src to tar";
let new_map =
......@@ -386,10 +399,10 @@ module G_graph = struct
then Error.run ~loc "[Graph.shift_edges] dependency from src to tar";
then Error.run ~loc "[Graph.shift_edges] dependency from tar to src";
let new_map =
......@@ -464,14 +477,14 @@ module G_graph = struct
(* list of the nodes *)
Gid_map.iter
(fun id node ->
bprintf buff "N%d %s;\n" id (G_node.to_gr node)
bprintf buff "N_%s %s;\n" (Gid.to_string id) (G_node.to_gr node)
) graph.map;
(* list of the edges *)
Gid_map.iter
(fun id node ->
Massoc.iter
Massoc_gid.iter
(fun tar edge ->
bprintf buff "N%d -[%s]-> N%d;\n" id (G_edge.to_string edge) tar
bprintf buff "N_%s -[%s]-> N_%s;\n" (Gid.to_string id) (G_edge.to_string edge) (Gid.to_string tar)
) (G_node.get_next node)
) graph.map;
......@@ -502,7 +515,7 @@ module G_graph = struct
let to_dep ?main_feat ?(deco=Deco.empty) graph =
let to_dep ?main_feat ?(deco=G_deco.empty) graph =
let buff = Buffer.create 32 in
bprintf buff "[GRAPH] { opacity=0; scale = 200; fontname=\"Arial\"; }\n";
......@@ -513,27 +526,27 @@ module G_graph = struct
List.iter
(fun (id, node) ->
if List.mem id deco.Deco.nodes
if List.mem id deco.G_deco.nodes
then bprintf buff
"N%d { %sforecolor=red; subcolor=red; }\n" id (G_fs.to_dep ?main_feat (G_node.get_fs node))
"N_%s { %sforecolor=red; subcolor=red; }\n" (Gid.to_string id) (G_fs.to_dep ?main_feat (G_node.get_fs node))
else bprintf buff
"N%d { %s }\n" id (G_fs.to_dep ?main_feat (G_node.get_fs node))
"N_%s { %s }\n" (Gid.to_string id) (G_fs.to_dep ?main_feat (G_node.get_fs node))
) snodes;
bprintf buff "} \n";
bprintf buff "[EDGES] { \n";
Gid_map.iter
(fun gid elt ->
Massoc.iter
Massoc_gid.iter
(fun tar g_edge ->
let deco = List.mem (gid,g_edge,tar) deco.Deco.edges in
bprintf buff "N%d -> N%d %s\n" gid tar (G_edge.to_dep ~deco g_edge)
let deco = List.mem (gid,g_edge,tar) deco.G_deco.edges in
bprintf buff "N_%s -> N_%s %s\n" (Gid.to_string gid) (Gid.to_string tar) (G_edge.to_dep ~deco g_edge)
) (G_node.get_next elt)
) graph.map;
Buffer.contents buff
let to_dot ?main_feat ?(deco=Deco.empty) graph =
let to_dot ?main_feat ?(deco=G_deco.empty) graph =
bprintf buff "digraph G {\n";
......@@ -543,18 +556,18 @@ module G_graph = struct
Gid_map.iter
(fun id node ->
bprintf buff " N%d [label=\"%s\", color=%s]\n"
id
bprintf buff " N_%s [label=\"%s\", color=%s]\n"
(Gid.to_string id)
(G_fs.to_dot ?main_feat (G_node.get_fs node))
(if List.mem id deco.Deco.nodes then "red" else "black")
(if List.mem id deco.G_deco.nodes then "red" else "black")
) graph.map;
Gid_map.iter
(fun id node ->
Massoc.iter
Massoc_gid.iter
(fun tar g_edge ->
let deco = List.mem (id,g_edge,tar) deco.Deco.edges in
bprintf buff " N%d -> N%d%s\n" id tar (G_edge.to_dot ~deco g_edge)
let deco = List.mem (id,g_edge,tar) deco.G_deco.edges in
bprintf buff " N_%s -> N_%s%s\n" (Gid.to_string id) (Gid.to_string tar) (G_edge.to_dot ~deco g_edge)
) graph.map;
......@@ -566,7 +579,7 @@ module G_graph = struct
(* is there an edge e out of node i ? *)
let edge_out graph node_id p_edge =
Massoc.exists (fun _ e -> P_edge.compatible p_edge e) (G_node.get_next node)
Massoc_gid.exists (fun _ e -> P_edge.compatible p_edge e) (G_node.get_next node)
end (* module G_graph *)
......@@ -5,14 +5,29 @@ open Grew_node
open Grew_utils
open Grew_command
module Deco: sig
module P_deco: sig
type t =
{ nodes: int list;
edges: (int * Label.t * int) list;
val empty:t
module G_deco: sig
type t =
val empty:t
module P_graph: sig
type t = P_node.t Pid_map.t
......@@ -41,6 +56,7 @@ module P_graph: sig
val roots: t -> Pid.t list
......@@ -64,37 +80,37 @@ module G_graph: sig
val of_conll: ?loc:Loc.t -> Conll.line list -> t
val to_gr: t -> string
val to_dot: ?main_feat:string -> ?deco:Deco.t -> t -> string
val to_dot: ?main_feat:string -> ?deco:G_deco.t -> t -> string
val to_sentence: ?main_feat:string -> t -> string
val to_dep: ?main_feat:string -> ?deco:Deco.t -> t -> string
val to_dep: ?main_feat:string -> ?deco:G_deco.t -> t -> string
type concat_item =
| Feat of (Gid.t * string)
| String of string
val add_edge: t -> int -> G_edge.t -> int -> t option
val del_edge : ?edge_ident: string -> Loc.t -> t -> int -> G_edge.t -> int -> t
val del_node : t -> int -> t
val add_edge: t -> Gid.t -> G_edge.t -> Gid.t -> t option
val del_edge : ?edge_ident: string -> Loc.t -> t -> Gid.t -> G_edge.t -> Gid.t -> t
val del_node : t -> Gid.t -> t
val add_neighbour : Loc.t -> t -> int -> G_edge.t -> (int * t)
val merge_node : Loc.t -> t -> int -> int -> t option
val add_neighbour : Loc.t -> t -> Gid.t -> G_edge.t -> (Gid.t * t)
val merge_node : Loc.t -> t -> Gid.t -> Gid.t -> t option
val shift_in : Loc.t -> t -> int -> int -> t
val shift_out : Loc.t -> t -> int -> int -> t
val shift_edges : Loc.t -> t -> int -> int -> t
val shift_in : Loc.t -> t -> Gid.t -> Gid.t -> t
val shift_out : Loc.t -> t -> Gid.t -> Gid.t -> t
val shift_edges : Loc.t -> t -> Gid.t -> Gid.t -> t
(** [update_feat tar_id tar_feat_name concat_items] sets the feature of the node [tar_id]
with feature name [tar_feat_name] to be the contatenation of values described by the [concat_items].
It returns both the new graph and the new feature value produced as the second element *)
val update_feat: ?loc:Loc.t -> t -> int -> string -> concat_item list -> (t * string)
val update_feat: ?loc:Loc.t -> t -> Gid.t -> string -> concat_item list -> (t * string)
val set_feat: ?loc:Loc.t -> t -> int -> string -> string -> t
val set_feat: ?loc:Loc.t -> t -> Gid.t -> string -> string -> t
val del_feat: t -> int -> string -> t
val del_feat: t -> Gid.t -> string -> t
(** [edge_out t id edge] returns true iff there is an out-edge from the node [id] with a label compatible with [edge] *)
val edge_out: t -> int -> P_edge.t -> bool
val edge_out: t -> Gid.t -> P_edge.t -> bool
val equals: t -> t -> bool
......@@ -10,7 +10,7 @@ module G_node = struct
type t = {
fs: G_fs.t;
pos: int option;
next: G_edge.t Massoc.t;
next: G_edge.t Massoc_gid.t;
let get_fs t = t.fs
......@@ -18,12 +18,12 @@ module G_node = struct
let set_fs t fs = {t with fs = fs}
let empty = { fs = G_fs.empty; pos = None; next = Massoc.empty }
let empty = { fs = G_fs.empty; pos = None; next = Massoc_gid.empty }
let to_string t =
Printf.sprintf " fs=[%s]\n next=%s\n"
(G_fs.to_string t.fs)
(Massoc.to_string G_edge.to_string t.next)
(Massoc_gid.to_string G_edge.to_string t.next)
let to_gr t =
sprintf "%s [%s] "
......@@ -31,7 +31,7 @@ module G_node = struct
(G_fs.to_gr t.fs)
let add_edge g_edge gid_tar t =
match Massoc.add gid_tar g_edge t.next with
match Massoc_gid.add gid_tar g_edge t.next with
| Some l -> Some {t with next = l}
| None -> None
......@@ -39,30 +39,30 @@ module G_node = struct
(ast_node.Ast.node_id,
{ fs = G_fs.build ast_node.Ast.fs;
pos = ast_node.Ast.position;
next = Massoc.empty;
next = Massoc_gid.empty;
let of_conll line = {
fs = G_fs.of_conll line;
pos = Some line.Conll.num;
let remove id_tar label t = {t with next = Massoc.remove id_tar label t.next}
let remove (id_tar : Gid.t) label t = {t with next = Massoc_gid.remove id_tar label t.next}
let remove_key node_id t =
try {t with next = Massoc.remove_key node_id t.next} with Not_found -> t
try {t with next = Massoc_gid.remove_key node_id t.next} with Not_found -> t
let merge_key ?(strict=false) src_id tar_id t =
try Some {t with next = Massoc.merge_key src_id tar_id t.next}
with Massoc.Duplicate -> if strict then None else Some t
try Some {t with next = Massoc_gid.merge_key src_id tar_id t.next}
with Massoc_gid.Duplicate -> if strict then None else Some t
let shift_out ?(strict=false) src_t tar_t =
try Some {tar_t with next = Massoc.disjoint_union src_t.next tar_t.next}
with Massoc.Not_disjoint -> if strict then None else Some tar_t
try Some {tar_t with next = Massoc_gid.disjoint_union src_t.next tar_t.next}
with Massoc_gid.Not_disjoint -> if strict then None else Some tar_t
let rm_out_edges t = {t with next = Massoc.empty}
let rm_out_edges t = {t with next = Massoc_gid.empty}
let build_neighbour t = {empty with pos = match t.pos with Some x -> Some (x+1) | None -> None}
......@@ -13,21 +13,21 @@ module G_node: sig
val get_fs: t -> G_fs.t
val get_next: t -> G_edge.t Massoc.t
val get_next: t -> G_edge.t Massoc_gid.t
val set_fs: t -> G_fs.t -> t
(* FIXME move Gid up and replace int by Gid.t *)
val remove: int -> G_edge.t -> t -> t
val remove: Gid.t -> G_edge.t -> t -> t
val remove_key: int -> t -> t
val remove_key: Gid.t -> t -> t
val merge_key: ?strict:bool -> int -> int -> t -> t option
val merge_key: ?strict:bool -> Gid.t -> Gid.t -> t -> t option
val shift_out: ?strict:bool -> t -> t -> t option
val rm_out_edges: t -> t
val add_edge: G_edge.t -> int -> t -> t option
val add_edge: G_edge.t -> Gid.t -> t -> t option
val build: Ast.node -> (Id.name * t)
val of_conll: Conll.line -> t
......@@ -63,7 +63,7 @@ module Rule = struct
type pid = Pid.t
(* the [gid] type is used for graph identifier *)
type gid = int
type gid = Gid.t
(* the rewriting depth is bounded to stop rewriting when the system is not terminating *)
let max_depth = ref 500
......@@ -280,8 +280,8 @@ module Rule = struct
let a_match_add edge matching = {matching with a_match = edge::matching.a_match }
let up_deco matching =
{ Deco.nodes = Pid_map.fold (fun _ gid acc -> gid::acc) matching.n_match [];
Deco.edges = List.fold_left (fun acc (_,edge) -> edge::acc) matching.a_match matching.e_match;
{ G_deco.nodes = Pid_map.fold (fun _ gid acc -> gid::acc) matching.n_match [];
G_deco.edges = List.fold_left (fun acc (_,edge) -> edge::acc) matching.a_match matching.e_match;
let find cnode ?loc (matching, created_nodes) =
......@@ -296,14 +296,14 @@ module Rule = struct
let down_deco (matching,created_nodes) commands =
Deco.nodes = List.fold_left
G_deco.nodes = List.fold_left
(fun acc -> function
| (Command.UPDATE_FEAT (tar_cn,_,_),loc)
| (Command.SHIFT_EDGE (_,tar_cn),loc) ->
(find tar_cn (matching, created_nodes)) :: acc
| _ -> acc
) [] commands;
| (Command.ADD_EDGE (src_cn,tar_cn,edge),loc) ->
(find src_cn (matching, created_nodes), edge, find tar_cn (matching, created_nodes)) :: acc
......@@ -364,7 +364,7 @@ module Rule = struct
let gid = Pid_map.find pid matching.n_match in
gid_map_exists (* should be Gid_map.exists with ocaml 3.12 *)
(fun _ node ->
List.exists (fun e -> P_edge.compatible edge e) (Massoc.assoc gid (G_node.get_next node))
List.exists (fun e -> P_edge.compatible edge e) (Massoc_gid.assoc gid (G_node.get_next node))
) graph.G_graph.map
| Feature_eq (pid1, feat_name1, pid2, feat_name2) ->
let gnode1 = Gid_map.find (Pid_map.find pid1 matching.n_match) graph.G_graph.map in
......@@ -393,7 +393,7 @@ module Rule = struct
let src_gid = Pid_map.find src_pid partial.sub.n_match in
let tar_gid = Pid_map.find tar_pid partial.sub.n_match in
let src_gnode = G_graph.find src_gid graph in
let g_edges = Massoc.assoc tar_gid (G_node.get_next src_gnode) in
let g_edges = Massoc_gid.assoc tar_gid (G_node.get_next src_gnode) in
match P_edge.match_list p_edge g_edges with
| P_edge.Fail -> (* no good edge in graph for this pattern edge -> stop here *)
......@@ -410,7 +410,7 @@ module Rule = struct
let candidates = (* candidates (of type (gid, matching)) for m(tar_pid) = gid) with new partial matching m *)
Massoc.fold_left
Massoc_gid.fold
(fun acc gid_next g_edge ->
match P_edge.match_ p_edge g_edge with
| P_edge.Fail -> (* g_edge does not fit, no new candidate *)
open Grew_graph
type graph = G_graph.t
type deco = Deco.t
type deco = G_deco.t
type module_name = string
type rule_app = {
rule_name: string;
up: Deco.t;
down: Deco.t;
up: G_deco.t;
down: G_deco.t;
(* the main type for display the result of a rewriting *)
......@@ -24,6 +24,6 @@ and big_step = {
small_step: (G_graph.t * rule_app) list;
let to_dot_graph ?main_feat ?(deco=Deco.empty) graph = G_graph.to_dot ?main_feat graph ~deco
let to_dep_graph ?main_feat ?(deco=Deco.empty) graph = G_graph.to_dep ?main_feat ~deco graph
let to_dot_graph ?main_feat ?(deco=G_deco.empty) graph = G_graph.to_dot ?main_feat graph ~deco
let to_dep_graph ?main_feat ?(deco=G_deco.empty) graph = G_graph.to_dep ?main_feat ~deco graph
let to_gr_graph graph = G_graph.to_gr graph
......@@ -4,7 +4,7 @@ open Grew_graph
type deco = Deco.t
......@@ -104,28 +104,6 @@ module Pid_map =
(* union of two maps*)
let union_map m m' = fold (fun k v m'' -> (add k v m'')) m m'
exception MatchNotInjective
* union of two injective maps having different ranges :
* \forall x \neq y \in m: m(x) \neq m(y)
* \forall x' \neq y' \in m': m'(x) \neq m'(y)W
* \forall x \in m /\ m': m(x) = m'(x)
* \forall x \in m : x \not\in\m' => \forall y \in m' m(x) \neq m'(y)
let union_if m m' =
let keys_m = keys m in
let keys_m' = keys m' in
let inter_keys = IntSet.inter keys_m keys_m' in
if IntSet.for_all (fun elt -> (find elt m) = (find elt m')) inter_keys
then
let keys_s_m' = IntSet.diff keys_m' inter_keys in
let range_m = range keys_m m in
let range_m' = range keys_s_m' m' in
if (IntSet.inter range_m range_m') = IntSet.empty
then union_map m m'
else raise MatchNotInjective
end (* module Pid_map *)
......@@ -133,8 +111,15 @@ module Pid_map =
module Gid = struct
type t = int
type t =
| Old of int
| New of int * int (* identifier for "created nodes" *)
let compare = Pervasives.compare
let to_string = function
| Old i -> sprintf "%d" i
| New (i,j) -> sprintf"%d__%d" i j
module Gid_map = Map.Make (Gid)
......@@ -361,6 +346,141 @@ module List_ = struct
module type OrderedType =
sig
type t
val compare: t -> t -> int
module type S =
sig
type key
type +'a t
val empty: 'a t
(* an empty list returned if the key is undefined *)
val assoc: key -> 'a t -> 'a list
val is_empty: 'a t -> bool
val to_string: ('a -> string) -> 'a t -> string
val iter: (key -> 'a -> unit) -> 'a t -> unit
val add: key -> 'a -> 'a t -> 'a t option
val fold: ('b -> key -> 'a -> 'b) -> 'b -> 'a t -> 'b
(* raise Not_found if no (key,elt) *)
