Commit 6a2327b3 authored by bguillaum's avatar bguillaum
cosmetic
git-svn-id: svn+ssh://scm.gforge.inria.fr/svn/semagramme/libcaml-grew/trunk@7420 7838e531-6607-4d57-9587-6c381814729c
parent 971d5500
......@@ -81,7 +81,6 @@ end (* module Pid *)
module Pid_map =
struct
include Map.Make (Pid)
(** returns the image of a map [m]*)
exception True
......@@ -101,13 +100,10 @@ module Pid_map =
let keys m =
fold (fun k v s -> (IntSet.add k s)) m IntSet.empty
(* union of two maps*)
let union_map m m' = fold (fun k v m'' -> (add k v m'')) m m'
end (* module Pid_map *)
module Gid = struct
......@@ -120,11 +116,12 @@ module Gid = struct
let to_string = function
| Old i -> sprintf "%d" i
| New (i,j) -> sprintf"%d__%d" i j
end (* module Gid *)
module Gid_map = Map.Make (Gid)
module Array_ = struct
let dicho_mem elt array =
let rec loop low high =
......@@ -156,9 +153,9 @@ module Array_ = struct
| middle when fst array.(middle) < elt -> loop (middle+1) high
| middle -> loop low (middle - 1) in
loop 0 ((Array.length array) - 1)
end (* module Array_ *)
module List_ = struct
let rec set position elt = function
| [] -> failwith "List_.set"
......@@ -253,7 +250,6 @@ module List_ = struct
| (k,v)::t when key>k -> (k,v) :: (sort_remove_assoc key t)
| (_,v)::t -> t
exception Usort
let rec usort_remove key = function
......@@ -344,15 +340,16 @@ module List_ = struct
(fun (acc,i) elt -> (f i acc elt, i+1))
(init,0) l
end (* module List_ *)
module type OrderedType =
sig
type t
val compare: t -> t -> int
end (* module type OrderedType *)
module type S =
sig
type key
......@@ -393,9 +390,9 @@ module type S =
val merge_key: key -> key -> 'a t -> 'a t
val exists: (key -> 'a -> bool) -> 'a t -> bool
end (* module type S *)
module Massoc_make (Ord: OrderedType) = struct
module M = Map.Make (Ord)
......@@ -480,8 +477,10 @@ module Massoc_make (Ord: OrderedType) = struct
) t
end (* module Massoc_make *)
module Massoc_gid = Massoc_make (Gid)
module Massoc = struct
(* Massoc is implemented with caml lists *)
(* invariant: we suppose that all 'a list in the structure are not empty! *)
......@@ -580,6 +579,7 @@ module Massoc = struct
let exists fct t = List.exists (fun (key,list) -> List.exists (fun value -> fct key value) list) t
end (* module Massoc *)
module Error = struct
exception Build of (string * Loc.t option)
......@@ -596,8 +596,9 @@ module Error = struct
let bug_ ?loc message = raise (Bug (message, loc))
let bug ?loc = Printf.ksprintf (bug_ ?loc)
end (* module Error *)
module Id = struct
type name = string
......@@ -612,8 +613,9 @@ module Id = struct
let build_opt string table =
try Some (Array_.dicho_find string table)
with Not_found -> None
end (* module Id *)
module Html = struct
let css = "<meta http-equiv=\"Content-Type\" content=\"text/html; charset=UTF-8\" />\n<link rel=\"stylesheet\" href=\"style.css\" type=\"text/css\">"
......@@ -634,8 +636,9 @@ module Html = struct
let leave out_ch =
fprintf out_ch "</body>\n";
fprintf out_ch "</html>\n";
end (* module Html *)
module Conll = struct
type line = {
line_num: int;
......@@ -682,8 +685,9 @@ module Conll = struct
let lines = File.read_ln file in
List.map parse lines
end (* module Conll *)
(* This module defines a type for lexical parameter (i.e. one line in a lexical file) *)
module Lex_par = struct
......@@ -767,8 +771,9 @@ module Lex_par = struct
| l -> Error.run "Lexical parameter are not functionnal"
end (* module Lex_par *)
(* copy from leopar *)
module Timeout = struct
exception Stop
......@@ -784,4 +789,4 @@ module Timeout = struct
| Some delay ->
if Unix.time () -. !counter > delay
then raise Stop
end (* module Timeout *)
