Commit 46a19265 authored by bguillaum's avatar bguillaum
add an optional header line in conll output
git-svn-id: svn+ssh://scm.gforge.inria.fr/svn/semagramme/libcaml-grew/trunk@7842 7838e531-6607-4d57-9587-6c381814729c
parent af0ba680
......@@ -9,7 +9,7 @@ open Grew_command
open Grew_graph
open Grew_rule
module Rewrite_history = struct
type t = {
......@@ -71,11 +71,16 @@ module Rewrite_history = struct
| _ -> Error.run "Not a single rewriting"
in loop t
let save_det_conll base t =
let save_det_conll ?header base t =
let rec loop t =
match (t.good_nf, t.bad_nf) with
| [],[] -> File.write (Instance.to_conll t.instance) (base^".conll")
| [one], [] -> loop one
let output =
match header with
| Some h -> sprintf "%% %s\n%s" h (Instance.to_conll t.instance)
| None -> Instance.to_conll t.instance in
File.write output (base^".conll")
| ([one], []) -> loop one
in loop t
......@@ -88,11 +93,9 @@ module Rewrite_history = struct
in loop t
end (* Rewrite_history *)
module Modul = struct
type t = {
......@@ -127,8 +130,9 @@ module Modul = struct
loc = ast_module.Ast.mod_loc;
} in
check modul; modul
end (* module Modul *)
module Sequence = struct
type t = {
......@@ -152,13 +156,14 @@ module Sequence = struct
loc = ast_sequence.Ast.seq_loc;
} in
check module_list sequence; sequence
end (* module Sequence *)
module Grs = struct
type t = {
labels: Label.t list; (* the list of global edge labels *)
modules: Modul.t list; (* the ordered list of modules used from rewriting *)
sequences: Sequence.t list;
......@@ -278,4 +283,4 @@ module Grs = struct
(fun modul ->
List.iter (fun filter -> fct modul.Modul.name filter) modul.Modul.filters
) grs.modules
end (* module Grs *)
......@@ -34,7 +34,7 @@ module Rewrite_history: sig
(** [save_det_gr base_name t] supposes that the current GRS is deterministic.
It writes exactly one output file named [base_name].gr with the unique normal form. *)
val save_det_gr: string -> t -> unit
val save_det_conll: string -> t -> unit
val save_det_conll: ?header:string -> string -> t -> unit
val det_dep_string: t -> string
......@@ -163,7 +163,7 @@ let save_conll base rew_hist = Rewrite_history.save_conll base rew_hist
let save_det_gr base rew_hist = Rewrite_history.save_det_gr base rew_hist
let save_det_conll base rew_hist = Rewrite_history.save_det_conll base rew_hist
let save_det_conll ?header base rew_hist = Rewrite_history.save_det_conll ?header base rew_hist
let det_dep_string rew_hist = Rewrite_history.det_dep_string rew_hist
