Commit 0c013298 authored by bguillaum's avatar bguillaum
fix bug when loading files (.grs ou .lp) with relative filename
git-svn-id: svn+ssh://scm.gforge.inria.fr/svn/semagramme/libcaml-grew/trunk@6811 7838e531-6607-4d57-9587-6c381814729c
parent 84a42fab
......@@ -101,6 +101,7 @@ module Ast = struct
confluent: bool;
module_doc:string;
mod_loc:Loc.t;
mod_dir: string; (* the directory where the module is defined (for lp file localisation) *)
type sequence = {
......@@ -94,6 +94,7 @@ module Ast : sig
confluent: bool;
module_doc:string;
mod_loc:Loc.t;
type sequence = {
......@@ -171,7 +171,7 @@ module Modul = struct
name = ast_module.Ast.module_id;
local_labels = locals;
bad_labels = List.map Label.from_string ast_module.Ast.bad_labels;
rules = List.map (Rule.build ~locals) ast_module.Ast.rules;
rules = List.map (Rule.build ~locals ast_module.Ast.mod_dir) ast_module.Ast.rules;
confluent = ast_module.Ast.confluent;
loc = ast_module.Ast.mod_loc;
} in
......@@ -164,7 +164,7 @@ module Rule = struct
| x::t -> Error.bug ~loc "Illegal feature definition '%s' in the lexical rule" x in
parse_pat_vars vars
let build ?(locals=[||]) rule_ast =
let build ?(locals=[||]) dir rule_ast =
let (param, pat_vars, cmd_vars) =
match rule_ast.Ast.param with
......@@ -173,7 +173,7 @@ module Rule = struct
let (pat_vars, cmd_vars) = parse_vars rule_ast.Ast.rule_loc vars in
let nb_pv = List.length pat_vars in
let nb_cv = List.length cmd_vars in
let param = Lex_par.load ~loc:rule_ast.Ast.rule_loc nb_pv nb_cv file in
let param = Lex_par.load ~loc:rule_ast.Ast.rule_loc dir nb_pv nb_cv file in
(Some param, pat_vars, cmd_vars) in
(* try *)
(* let lines = File.read file in *)
......@@ -39,9 +39,12 @@ module Rule : sig
val get_name: t -> string
(** [get_loc t] returns the file location of the rule definition *)
val get_loc: t -> Loc.t
val build: ?locals:Label.decl array -> Ast.rule -> t
(** [build ?local dir ast_rule] returns the Rule.t value corresponding to [ast_rule].
[dir] is used for localisation of lp files *)
val build: ?locals:Label.decl array -> string -> Ast.rule -> t
(* raise Stop if some command fails to apply *)
val normalize:
......@@ -503,9 +503,14 @@ module Lex_par = struct
Str.global_replace (Str.regexp "\\( \\|\t\\)*$") ""
(Str.global_replace (Str.regexp "^\\( \\|\t\\)*") "" s)
let load ?loc nb_p nb_c file =
let load ?loc dir nb_p nb_c file =
try
let full_file =
if Filename.is_relative file
then Filename.concat dir file
else file in
let lines = File.read full_file in
let param =
(List.map
(fun line ->
......@@ -514,12 +519,16 @@ module Lex_par = struct
| [args] when nb_c = 0 ->
(match Str.split (Str.regexp "#") args with
| l when List.length l = nb_p -> (l,[])
| _ -> Error.bug "Illegal param line in file \"%s\", the line \"%s\" doesn't contain %d args" file line nb_p)
| _ -> Error.bug
full_file line nb_p)
| [args; values] ->
(match (Str.split (Str.regexp "#") args, Str.split (Str.regexp "#") values) with
| (lp,lc) when List.length lp = nb_p && List.length lc = nb_c -> (lp,lc)
| _ -> Error.bug "Illegal param line in file \"%s\", the line \"%s\" doesn't contain %d args and %d values" file line nb_p nb_c)
| _ -> Error.bug "Illegal param line in file '%s' line '%s'" file line
| _ -> Error.bug
full_file line nb_p nb_c)
| _ -> Error.bug "Illegal param line in file '%s' line '%s'" full_file line
) lines
) in
param
......@@ -177,8 +177,8 @@ end
module Lex_par: sig
type t
(** [load ?loc nb_pattern_var nb_command_var file] *)
val load: ?loc: Loc.t -> int -> int -> string -> t
(** [load ?loc local_dir_name nb_pattern_var nb_command_var file] *)
val load: ?loc: Loc.t -> string -> int -> int -> string -> t
(** [filter index atom t] returns the subset of [t] which contains only entries
which refers to [atom] at the [index]^th pattern_var.
......@@ -232,7 +232,8 @@ grew_module:
rules = begin match r with None -> [] | Some r -> r; end;
confluent = conf;
module_doc = (match doc with Some d -> d | None -> "");
mod_loc = (!Parser_global.current_file, snd id);
mod_dir = "";
......@@ -62,20 +62,22 @@ let parse_handle file fct lexbuf =
let grs_of_file main_file =
let grs_with_includes = parse_file_to_grs_with_includes main_file in
let rec flatten_modules = function
let rec flatten_modules current_file = function
| Ast.Modul m :: tail -> m :: (flatten_modules tail)
{m with Ast.mod_dir = Filename.dirname current_file}
:: (flatten_modules current_file tail)
| Ast.Includ (inc_file,loc) :: tail ->
let sub_file =
if Filename.is_relative inc_file
then Filename.concat (Filename.dirname main_file) inc_file
then Filename.concat (Filename.dirname current_file) inc_file
else inc_file in
(flatten_modules (parse_file_to_module_list loc sub_file))
@ (flatten_modules tail) in
(flatten_modules sub_file (parse_file_to_module_list loc sub_file))
@ (flatten_modules current_file tail) in
Ast.domain = grs_with_includes.Ast.domain_wi;
Ast.labels = grs_with_includes.Ast.labels_wi;
Ast.modules = flatten_modules grs_with_includes.Ast.modules_wi;
Ast.modules = flatten_modules main_file grs_with_includes.Ast.modules_wi;
Ast.sequences = grs_with_includes.Ast.sequences_wi;
