Commit acec33ad authored by Bruno Guillaume's avatar Bruno Guillaume
version 0.45 of libcaml-grew
parent b996afef
...@@ -10,7 +10,37 @@ menu = "main" ...@@ -10,7 +10,37 @@ menu = "main"
The symbol ":warning:" indicates changes that may break backward compatibility. The symbol ":warning:" indicates changes that may break backward compatibility.
# [last release] Version 0.44 on September 05, 2017 # **last release** Version 0.45 on October 10, 2017
* features structures given in column 10 of ConLL are kept in the output
* :warning: new grs syntax ([grs](../grs)) is required; old syntax can be used with the command line argument `-old_grs`
* :warning: in patterns, implicit node declaration is available only for nodes in edge (see below)
### Implicit nodes in version 0.45
In pattern, you can refer only to nodes which are explicitely declared or declared in a edge declaration.
The following patterns used to be valid (with a implicit declaration of node `M`), but there are not anymore
```grew
pattern { N[cat=NOUN]; M < N }
pattern { N[cat=NOUN]; M.cat = VERB }
pattern { N[cat=NOUN]; M -[obj]-> * }
They have to be replaced by, respectively:
```grew
pattern { N[cat=NOUN]; M[]; M < N }
pattern { N[cat=NOUN]; M[]; M.cat = VERB }
pattern { N[cat=NOUN]; M[]; M -[obj]-> * }
But it is still possible to write
```grew
pattern { N[cat=NOUN]; N -[obj]-> M }
# Version 0.44 on September 05, 2017
* :warning: new grs syntax (with package and strategies), see [grs](../grs). * :warning: new grs syntax (with package and strategies), see [grs](../grs).
# Vversion 0.43 on May 23, 2017 # Vversion 0.43 on May 23, 2017
...@@ -16,7 +16,7 @@ ...@@ -16,7 +16,7 @@
<li class="section">Use Grew</li> <li class="section">Use Grew</li>
<li><a href="/installation">Installation</a></li> <li><a href="/installation">Installation</a></li>
<li><a href="/run">Run Grew</a></li> <li><a href="/run">Run Grew</a></li>
<li><a href="/whats">version 0.44: what's new</a></li> <li><a href="/whats">version 0.45: what's new</a></li>
<hr/> <hr/>
<li class="section">Available GRS</li> <li class="section">Available GRS</li>
