Commit bd40d350 authored by Bruno Guillaume's avatar Bruno Guillaume
version 1.1.0
parent 8a64639b
## 1.0.1 (2018/09/16) ## 1.1.0 (2018/11/23)
* Follow libcaml-grew versioning
### 1.0.1 (2018/09/16)
* Fix invalid JSON output in “grew grep” * Fix invalid JSON output in “grew grep”
# 1.0.0 (2018/09/10) # 1.0.0 (2018/09/10)
...@@ -16,27 +19,27 @@ ...@@ -16,27 +19,27 @@
* new json output for grep mode * new json output for grep mode
* -safe_commands option * -safe_commands option
## 0.46.2 (2017/12/17) ### 0.46.2 (2017/12/17)
* Fix doc and dev call to gui * Fix doc and dev call to gui
## 0.46.1 (2017/12/14) ### 0.46.1 (2017/12/14)
* remove all code refering to Dep2pict * remove all code refering to Dep2pict
# 0.46.0 (2017/12/14) ## 0.46.0 (2017/12/14)
* Remove GUI (now available in a different opam package `grew_gui`) * Remove GUI (now available in a different opam package `grew_gui`)
* New command line parsing of arguments, see `grew help` * New command line parsing of arguments, see `grew help`
## 0.45.1 (2017/12/07) ### 0.45.1 (2017/12/07)
Bugfix: [#3](https://gitlab.inria.fr/grew/grew/issues/3) (Bug in GUI with graphviz 2.40) Bugfix: [#3](https://gitlab.inria.fr/grew/grew/issues/3) (Bug in GUI with graphviz 2.40)
# 0.45.0 (2017/10/10) ## 0.45.0 (2017/10/10)
The version number is aligned of the version number of `libcaml-grew` (hence, the jump from 33 to 45!) The version number is aligned of the version number of `libcaml-grew` (hence, the jump from 33 to 45!)
* `-old_grs` option * `-old_grs` option
* `-fullscreen` option * `-fullscreen` option
* GUI can now load a corpus: the option `-gr` has disapear, `-i` is used instead * GUI can now load a corpus: the option `-gr` has disapear, `-i` is used instead
# 0.33.0 (2017/09/05) ## 0.33.0 (2017/09/05)
* adapt to new GRS definition and restrict usage to deterministic strategies fir a given GRS. * adapt to new GRS definition and restrict usage to deterministic strategies fir a given GRS.
# 0.32.0 (2017/04/18) ## 0.32.0 (2017/04/18)
* adapt to libcaml-grew 0.42.0 (dependence on yojson) * adapt to libcaml-grew 0.42.0 (dependence on yojson)
