Commit 2586b466 authored by Bruno Guillaume's avatar Bruno Guillaume
version 0.31.1: adapt to new libraries
parent 4920b479
S src S src
B _build/src B _build/src
PKG yojson log conll dep2pict libgrew_dev lablgtk2 lablwebkit PKG yojson log svg conll dep2pict libgrew_dev lablgtk2 lablwebkit
true: package(str, ANSITerminal, camomile, cairo2, log, conll, dep2pict, lablgtk2, lablgtk2.rsvg, lablgtk2.glade, lablwebkit) true: package(containers, str, ANSITerminal, camomile, cairo2, log, svg, conll, dep2pict, lablgtk2, lablgtk2.rsvg, lablgtk2.glade, lablwebkit)
true: bin_annot
\ No newline at end of file
...@@ -285,15 +285,15 @@ let full () = ...@@ -285,15 +285,15 @@ let full () =
let pattern = Pattern.load ?domain pattern_file in let pattern = Pattern.load ?domain pattern_file in
if not (List.mem node_id (Pattern.pid_list pattern)) if not (List.mem node_id (Pattern.pid_name_list pattern))
then (Log.fmessage "The requester node_id \"%s\" is not defined in the pattern" node_id; exit 1) then (Log.fmessage "The requested node_id \"%s\" is not defined in the pattern" node_id; exit 1)
else else
(* get the array of graphs to explore *) (* get the array of graphs to explore *)
let graph_array = Corpus.get_graphs ?domain data_file in let graph_array = Corpus.get_graphs ?domain data_file in
match !Grew_args.output_dir with match !Grew_args.output_dir with
| None -> | None ->
Array.iter Array.iter
(fun (name,graph) -> (fun (name,graph) ->
let matchings = Graph.search_pattern ?domain pattern graph in let matchings = Graph.search_pattern ?domain pattern graph in
...@@ -321,7 +321,7 @@ let full () = ...@@ -321,7 +321,7 @@ let full () =
let filename = Filename.concat dir (sprintf "%s__%d.svg" name graph_node_id) in let filename = Filename.concat dir (sprintf "%s__%d.svg" name graph_node_id) in
if Sys.file_exists filename if Sys.file_exists filename
then (Log.message "Try to erase a previous file"; exit 1) then (Log.message "Try to erase a previous file"; exit 1)
else else
begin begin
let deco = Deco.build pattern matching in let deco = Deco.build pattern matching in
let dep = Graph.to_dep ?domain ~deco graph in let dep = Graph.to_dep ?domain ~deco graph in
