Commit 024e9590 authored by Bruno Guillaume's avatar Bruno Guillaume
version 0.48.0
parent 6d0d10ea
## 0.48.0 (2018/06/05)
* Follow libcaml-grew versioning
## 0.47.0 (2018/03/18) ## 0.47.0 (2018/03/18)
* Adapt to libcaml-grew 0.47 * Adapt to libcaml-grew 0.47
* new json output for grep mode * new json output for grep mode
...@@ -66,7 +66,7 @@ module Grew_args = struct ...@@ -66,7 +66,7 @@ module Grew_args = struct
"usage: grew grep [<args>]"; "usage: grew grep [<args>]";
"This subcommand search for a pattern in a corpus."; "This subcommand searches for a pattern in a corpus.";
"args are optionnal and can be change in the GUI:"; "args are optionnal and can be change in the GUI:";
" -pattern <pat> The pattern to search for"; " -pattern <pat> The pattern to search for";
...@@ -80,7 +80,7 @@ module Grew_args = struct ...@@ -80,7 +80,7 @@ module Grew_args = struct
"usage: grew transform [<args>]"; "usage: grew transform [<args>]";
"This subcommand apply grs to a graph or a corpus."; "This subcommand applies a grs to a graph or a corpus.";
"Required arguments:"; "Required arguments:";
" -grs <file> The Graph Rewriting System to load"; " -grs <file> The Graph Rewriting System to load";
