Commit 65189347 authored by MEVEL Glen's avatar MEVEL Glen
wrote make_archive.sh, updated README
parent 4b59cf37
...@@ -5,3 +5,4 @@ Makefile.coq ...@@ -5,3 +5,4 @@ Makefile.coq
*.glob *.glob
*.vo *.vo
.lia.cache .lia.cache
*.tar.gz
## Compiling ## Compiling
The project is known to compile with:
* Coq 8.7.2
* iris-coq dev.2018-04-10.0 (development version of Iris)
To install Iris, follow instructions [there][iris-coq].
To compile the Coq scripts: To compile the Coq scripts:
cd src/ cd src/
...@@ -11,21 +17,33 @@ file `Makefile.coq`. ...@@ -11,21 +17,33 @@ file `Makefile.coq`.
Other recipes are available, such as `all`, `clean` and `userinstall` (Makefile Other recipes are available, such as `all`, `clean` and `userinstall` (Makefile
taken from [here][coqproject]). taken from [here][coqproject]).
To create an archive of the project:
./make_archive.sh
[iris-coq]: https://gitlab.mpi-sws.org/FP/iris-coq/blob/master/README.md
[coqproject]: https://blog.zhenzhang.me/2016/09/19/coq-dev.html [coqproject]: https://blog.zhenzhang.me/2016/09/19/coq-dev.html
## Index of modules ## Index of modules
Important modules are highlighted.
* `Misc`: some basic things * `Misc`: some basic things
* `Auth_nat`, `Auth_mnat`: simple lemmas about the authoritative resources on * `Auth_nat`, `Auth_mnat`: simple lemmas about the authoritative resources on
(ℕ, +) and (ℕ, max) (ℕ, +) and (ℕ, max)
* `Reduction`: generic lemmas about reduction, safety, closedness, fresh * `Reduction`: generic lemmas about reduction, safety, closedness, fresh
locations… [should be renamed or split into several files] locations… [should be renamed or split into several files]
* `Tactics`: tactics that help reducing concrete terms * `Tactics`: helper tactics to reduce concrete terms
* `Translation`: definition of the translation and syntactic lemmas about it * __`Translation`: definition of the translation and syntactic lemmas about
* `Simulation`: Lemmas about the operational semantics of the translation it__
* `TimeCredits`: implementation of time credits * __`Simulation`: generic definition of `tick`; operational lemmas about the
* `TimeReceipts`: implementation of time receipts translation with that `tick`__
* `Examples`: a (too) simple example illustrating the use of time credits * __`TimeCredits`: interface, implementation, and proof of soundness for time
* `Thunks`: implementation of timed thunks using time credits credits (plus a proof-mode tactic `wp_pay`)__
* `test`: an alternative proof of the main theorem of time credits, that does * __`TimeCreditsAltProofs`: alternative proofs of the soundness theorem of
not rely on the unsafe behaviour of `tick` [to be merged into `TimeCredits`] time credits, that does not rely on the unsafe behavior of `tick`__
* __`TimeReceipts`: interface, implementation, and proof of soundness for time
receipts (both exclusive and persistent)__
* `Examples`: a very simple example illustrating the use of time credits to
specify a program with lists
* __`Thunks`: implementation of timed thunks using time credits__
ARCHIVE=iris-time-proofs.tar.gz
rm -f $ARCHIVE
tar -czvf $ARCHIVE README.md src/Makefile src/_CoqProject src/*.v
