Commit cbbf1156 authored by MEVEL Glen's avatar MEVEL Glen
simplifying the representation predicates in ClockIntegers.v makes things even more trivial
parent dabf169f
...@@ -16,28 +16,29 @@ Section machine_int. ...@@ -16,28 +16,29 @@ Section machine_int.
Context `{heapG Σ}. Context `{heapG Σ}.
Definition is_machine_int (v : val) (n : Z) : iProp Σ := Definition is_machine_int (n : Z) : iProp Σ :=
v = #n min_int n < max_int%I. min_int n < max_int%I.
Definition machine_int_add : val := Definition machine_int_add : val :=
λ: "x" "y", λ: "x" "y",
("x" + "y" + #max_int) `rem` #max_uint - #max_int. ("x" + "y" + #max_int) `rem` #max_uint - #max_int.
Lemma machine_int_add_spec v1 n1 v2 n2 : Lemma machine_int_add_spec n1 n2 :
{{{ is_machine_int v1 n1 is_machine_int v2 n2 min_int n1+n2 < max_int }}} {{{ is_machine_int n1 is_machine_int n2 min_int n1+n2 < max_int }}}
machine_int_add v1 v2 machine_int_add #n1 #n2
{{{ v, RET v ; is_machine_int v (n1+n2) }}}. {{{ RET #(n1+n2) ; is_machine_int (n1+n2) }}}.
Proof. Proof.
iIntros (Φ) "([->_] & [->_] & %) Post". iIntros (Φ) "(_ & _ & %) Post". repeat (wp_pure _).
repeat (wp_pure _). iApply "Post". iPureIntro.
split ; last done. do 2 f_equal.
(* boring arithmetic proof: *) (* boring arithmetic proof: *)
assert ((n1 + n2 + max_int) `rem` max_uint = n1 + n2 + max_int). { assert ((n1 + n2 + max_int) `rem` max_uint - max_int = n1 + n2) as ->. {
(*assert (min_int = -max_int) by done. assert ((n1 + n2 + max_int) `rem` max_uint = n1 + n2 + max_int). {
assert (max_int + max_int = max_uint) by done.*) (*assert (min_int = -max_int) by done.
apply Z.rem_small. unfold min_int, max_uint in *. lia. assert (max_int + max_int = max_uint) by done.*)
lia.
lia. by iApply "Post".
Qed. Qed.
End machine_int. End machine_int.
...@@ -48,8 +49,8 @@ Context `{timeReceiptHeapG Σ}. ...@@ -48,8 +49,8 @@ Context `{timeReceiptHeapG Σ}.
Context (nmax : nat). Context (nmax : nat).
Context `(nmax max_int). Context `(nmax max_int).
Definition is_clock_int (v : val) (n : nat) : iProp Σ := Definition is_clock_int (n : nat) : iProp Σ :=
(v = #n TR n)%I. TR n.
Lemma TR_weaken (n n : nat) : Lemma TR_weaken (n n : nat) :
(n n)%nat (n n)%nat
...@@ -68,25 +69,21 @@ Definition is_clock_int (v : val) (n : nat) : iProp Σ := ...@@ -68,25 +69,21 @@ Definition is_clock_int (v : val) (n : nat) : iProp Σ :=
done. done.
Qed. Qed.
Lemma clock_int_add_spec v1 n1 v2 n2 : Lemma clock_int_add_spec n1 n2 :
TR_invariant nmax - TR_invariant nmax -
{{{ is_clock_int v1 n1 is_clock_int v2 n2 }}} {{{ is_clock_int n1 is_clock_int n2 }}}
{{{ v, RET v ; is_clock_int v (n1+n2) }}}. {{{ RET #(n1+n2) ; is_clock_int (n1+n2) }}}.
Proof. Proof.
iIntros "#Htrinv" (Φ) "!# ([->H1] & [->H2]) Post". iIntros "#Htrinv" (Φ) "!# (H1 & H2) Post".
iAssert (TR (n1+n2)) with "[H1 H2]" as "H" ; first by (rewrite TR_plus ; iFrame). iAssert (TR (n1+n2)) with "[H1 H2]" as "H" ; first by (rewrite TR_plus ; iFrame).
iDestruct (TR_lt_nmax with "Htrinv H") as ">(H & %)" ; first done. iDestruct (TR_lt_nmax with "Htrinv H") as ">(H & %)" ; first done.
wp_apply (machine_int_add_spec _ n1 _ n2 with "[] [H Post]") . wp_apply (machine_int_add_spec n1 n2 with "[] [H Post]") .
iSplitR ; last iSplitR ; iPureIntro. iPureIntro. unfold min_int in *. lia.
- split ; first done. unfold min_int in *. lia.
- unfold min_int in *. lia.
iNext ; iIntros (v) "[->%]". iApply "Post". iFrame "H". iNext ; iIntros "%". iApply "Post". iFrame "H".
iPureIntro. do 2 f_equal. lia.
Qed. Qed.
...@@ -98,8 +95,8 @@ Context `{timeReceiptHeapG Σ}. ...@@ -98,8 +95,8 @@ Context `{timeReceiptHeapG Σ}.
Definition is_snapclock_int (v : val) (n : nat) : iProp Σ := Definition is_snapclock_int (n : nat) : iProp Σ :=
(v = #n TRdup n)%I. TRdup n.
Lemma TRdup_weaken (n n : nat) : Lemma TRdup_weaken (n n : nat) :
(n n)%nat (n n)%nat
...@@ -118,52 +115,41 @@ Definition is_snapclock_int (v : val) (n : nat) : iProp Σ := ...@@ -118,52 +115,41 @@ Definition is_snapclock_int (v : val) (n : nat) : iProp Σ :=
done. done.
Qed. Qed.
Lemma snapclock_int_incr_spec v1 n1 : Lemma snapclock_int_incr_spec n1 :
{{{ is_snapclock_int v1 n1 }}} {{{ is_snapclock_int n1 }}}
tock #() ;; machine_int_add v1 #1 tock #() ;; machine_int_add #n1 #1
{{{ v, RET v ; is_snapclock_int v (n1+1) }}}. {{{ RET #(n1+1) ; is_snapclock_int (n1+1) }}}.
Proof. Proof.
iIntros "#Htrinv" (Φ) "!# [->H1] Post". iIntros "#Htrinv" (Φ) "!# H1 Post".
wp_apply (tock_spec_simple nmax #() with "Htrinv H1"). iIntros "(_ & H)". wp_apply (tock_spec_simple nmax #() with "Htrinv H1"). iIntros "(_ & H)".
iDestruct (TRdup_lt_nmax with "Htrinv H") as ">(H & %)" ; first done. iDestruct (TRdup_lt_nmax with "Htrinv H") as ">(H & %)" ; first done.
wp_seq. wp_seq.
rewrite (_ : (#n1)%E = of_val (#n1)%V) // ; wp_apply (machine_int_add_spec n1 1 with "[] [H Post]") .
rewrite (_ : (#1)%E = of_val (#1)%V) //.
wp_apply (machine_int_add_spec _ n1 _ 1 with "[] [H Post]") .
- split ; first done. done.
iNext ; iIntros (v) "[->%]". iNext ; iIntros "%". iApply "Post". iFrame "H".
Qed. Qed.
Lemma snapclock_int_add_spec v1 n1 v2 n2 w m : Lemma snapclock_int_add_spec n1 n2 m :
{{{ is_snapclock_int v1 n1 is_snapclock_int v2 n2 {{{ is_snapclock_int n1 is_snapclock_int n2
is_snapclock_int w m n1+n2 m }}} is_snapclock_int m n1+n2 m }}}
{{{ v, RET v ; is_snapclock_int v (n1+n2) }}}. {{{ RET #(n1+n2) ; is_snapclock_int (n1+n2) }}}.
Proof. Proof.
iIntros "#Htrinv" (Φ) "!# ([->H1] & [->H2] & [_ Hm] & %) Post". iIntros "#Htrinv" (Φ) "!# (_ & _ & Hm & %) Post".
iDestruct (TRdup_lt_nmax with "Htrinv Hm") as ">(Hm & %)" ; first done. iDestruct (TRdup_lt_nmax with "Htrinv Hm") as ">(Hm & %)" ; first done.
iDestruct (TRdup_weaken m (n1 + n2) with "Hm") as "H" ; first lia. iDestruct (TRdup_weaken m (n1 + n2) with "Hm") as "H" ; first lia.
Qed. Qed.
