Commit a18a1836 authored by MEVEL Glen's avatar MEVEL Glen
update instructions in README
parent 270ae8c3
## Requirements
## Building
The project is known to compile with:
* Coq 8.9.1
* coq-iris dev.2019-09-20.0.b958d569 (development version of Iris)
* coq-tlc 20181116 (for the proof of union-find)
As those dependencies (especially Iris) often make breaking changes,
compatibility with other versions is not guaranteed.
### Step 1: Install opam
### Step 1: Creating an opam switch
_If opam is not already installed:_ See instructions [there][install-opam] to
install it; then:
opam init --comp=4.06.1
opam init --comp=4.09.1
eval $(opam config env)
(This will create a `~/.opam` directory.)
_If opam is already installed:_ Create a new switch for the project:
opam switch iris-time-proofs --alias-of 4.06.1 # for opam 1.x
opam switch create iris-time-proofs 4.06.1 # for opam 2.x
opam switch iris-time-proofs --alias-of 4.09.1 # for opam 1.x
opam switch create iris-time-proofs ocaml-base-compiler.4.09.1 # for opam 2.x
### Step 2: Install Coq
### Step 2: Installing the dependencies
In an opam switch as created above, the commands
opam repo add coq-released https://coq.inria.fr/opam/released
opam update
opam install -j4 -v coq.8.9.1
If you want to use CoqIDE (a graphical, interactive toplevel for Coq), install
it as well:
make build-dep
# NOTE: this version of CoqIDE is only available if using opam 2.x
opam install coqide.8.9.1
will pin and install the dependencies at the correct version.
### Step 3: Install Iris and TLC at the required versions
If you want to browse the Coq development using CoqIDE (a graphical, interactive
toplevel for Coq), install it as well:
opam repo add iris-dev https://gitlab.mpi-sws.org/FP/opam-dev.git
make build-dep
opam install coqide
## Compiling
### Step 3: Compiling the proof scripts
To compile the Coq scripts:
When all required libraries can be found (e.g. in an opam switch as configured
above), compile the proof scripts with:
make -j4
The first time (and each time `_CoqProject` is updated), it also creates the
files `Makefile.coq` and `Makefile.coq.conf`.
Other recipes are available, such as `all`, `clean` and `userinstall` (Makefile
taken from [here][coqproject]).
Other recipes are available, such as `all`, `clean` and `userinstall`.
To create an archive of the project:
./make_archive.sh
[install-opam]: https://opam.ocaml.org/doc/Install.html
[coq-iris]: https://gitlab.mpi-sws.org/FP/iris-coq
[coqproject]: https://blog.zhenzhang.me/2016/09/19/coq-dev.html
## Index of modules
