Commit 8e883d20 authored by MEVEL Glen's avatar MEVEL Glen
updated README with more detailed installation instructions
parent 65189347
## Compiling ## Requirements
The project is known to compile with: The project is known to compile with:
* Coq 8.7.2 * Coq 8.7.2
* iris-coq dev.2018-04-10.0 (development version of Iris) * coq-iris dev.2018-04-10.0 (development version of Iris)
### Step 1: Install opam
See instructions [there][install-opam]; then:
opam init --comp=4.06.1
(This will create a `~/.opam` directory.)
### Step 2: Install Coq
opam repo add coq-released https://coq.inria.fr/opam/released
opam update
opam install -j4 -v coq.8.7.2
If you want to use CoqIDE (a graphical, interactive toplevel for Coq), install
it as well:
To install Iris, follow instructions [there][iris-coq]. opam install coqide.8.7.2
### Step 3: Install a development version of Iris
opam repo add iris-dev https://gitlab.mpi-sws.org/FP/opam-dev.git
opam update
# to get a specific development version:
opam pin add coq-iris -k version dev.2018-04-10.0
# OR, to get the latest development version (beware that the analysis of
# dependencies can be very slow):
opam install coq-iris
(This will also install `coq-stdpp`, another Coq library made available through
the same repo.)
More info on the Coq development of Iris: [there][coq-iris].
## Compiling
To compile the Coq scripts: To compile the Coq scripts:
...@@ -21,7 +56,8 @@ To create an archive of the project: ...@@ -21,7 +56,8 @@ To create an archive of the project:
./make_archive.sh ./make_archive.sh
[iris-coq]: https://gitlab.mpi-sws.org/FP/iris-coq/blob/master/README.md [install-opam]: https://opam.ocaml.org/doc/Install.html
[coq-iris]: https://gitlab.mpi-sws.org/FP/iris-coq
[coqproject]: https://blog.zhenzhang.me/2016/09/19/coq-dev.html [coqproject]: https://blog.zhenzhang.me/2016/09/19/coq-dev.html
## Index of modules ## Index of modules
