Commit 468dcbcd authored by Jacques-Henri Jourdan's avatar Jacques-Henri Jourdan
Use Coq 8.9.1.
parent 9430d201
......@@ -36,7 +36,7 @@ build-coq.8.9.1:
build-iris.dev:
<<: *template
variables:
OPAM_PINS: "coq version 8.9.0 coq-stdpp.dev git git+https://gitlab.mpi-sws.org/iris/stdpp.git#$STDPP_REV coq-iris.dev git git+https://gitlab.mpi-sws.org/iris/iris.git#$IRIS_REV"
OPAM_PINS: "coq version 8.9.1 coq-stdpp.dev git git+https://gitlab.mpi-sws.org/iris/stdpp.git#$STDPP_REV coq-iris.dev git git+https://gitlab.mpi-sws.org/iris/iris.git#$IRIS_REV"
except:
only:
- triggers
