Commit 0da70c19 authored by Ralf Jung's avatar Ralf Jung
this does not work with Coq 8.11
parent a88f7c21
......@@ -10,7 +10,7 @@ build: [make "-j%{jobs}%"]
install: [make "install"]
remove: [ "sh" "-c" "rm -rf '%{lib}%/coq/user-contrib/iris_time" ]
depends: [
"coq" { (>= "8.9.1" & < "8.12~") | (= "dev") }
"coq" { (>= "8.9.1" & < "8.11~") | (= "dev") }
"coq-iris" { (= "dev.2020-05-24.1.76bec8b7") | (= "dev") }
"coq-tlc" { (= "20181116") | (= "dev") }
