Commit 540685e9 authored by luc chatty's avatar luc chatty
Merge branch 'feature/PATREG-31.b' into 'feature/PATREG-31'
Feature/patreg 31.b
See merge request !3
parents c17084cc 39455c6b
Pipeline #131954 failed with stages
in 2 minutes and 15 seconds
......@@ -17,6 +17,11 @@
<packaging>ejb</packaging>
<properties>
<postgresql.hostandport>localhost:5432</postgresql.hostandport>
<postgresql.gazelle.password>changeIt</postgresql.gazelle.password>
</properties>
<build>
<resources>
<resource>
......@@ -161,6 +166,98 @@
</activation>
<build>
<plugins>
<plugin>
<groupId>org.codehaus.mojo</groupId>
<artifactId>sql-maven-plugin</artifactId>
<version>1.5</version>
<dependencies>
<!-- specify the dependent jdbc driver here -->
<dependency>
<groupId>postgresql</groupId>
<artifactId>postgresql</artifactId>
<version>9.1-901.jdbc4</version>
</dependency>
</dependencies>
<!-- common configuration shared by all executions -->
<configuration>
<driver>org.postgresql.Driver</driver>
<url>jdbc:postgresql://${postgresql.hostandport}/pam-simulator-PR-test</url>
<username>postgres</username>
<password>root</password>
<!-- You can comment out username/password configurations and have
maven to look them up in your settings.xml using ${settingsKey} -->
<settingsKey>sensibleKey</settingsKey>
</configuration>
<executions>
<execution>
<id>drop-db-before-test-if-any</id>
<phase>generate-test-resources</phase>
<goals>
<goal>execute</goal>
</goals>
<configuration>
<!-- need another database to drop the targeted one -->
<url>jdbc:postgresql://${postgresql.hostandport}/postgres</url>
<autocommit>true</autocommit>
<sqlCommand>drop database "pam-simulator-PR-test"</sqlCommand>
<!-- ignore error when database is not avaiable -->
<onError>continue</onError>
</configuration>
</execution>
<execution>
<id>create-db-before-test</id>
<goals>
</goals>
<configuration>
<sqlCommand>create database "pam-simulator-PR-test"</sqlCommand>
</configuration>
</execution>
<execution>
<id>create-user-before-test</id>
<goals>
</goals>
<configuration>
<sqlCommand>create user gazelle with password '${postgresql.gazelle.password}'</sqlCommand>
</configuration>
</execution>
<execution>
<id>create-schema</id>
<goals>
</goals>
<configuration>
<srcFiles>
<srcFile>src/main/resources/sql/schema.sql</srcFile>
</srcFiles>
</configuration>
</execution>
</executions>
</plugin>
<plugin>
<groupId>org.wildfly.plugins</groupId>
<artifactId>wildfly-maven-plugin</artifactId>
......@@ -190,10 +287,10 @@
<properties>
<jndi-name>java:/jboss/datasources/patientRegistryDS</jndi-name>
<enabled>true</enabled>
<connection-url>jdbc:postgresql://localhost:5432/pam-simulator</connection-url>
<connection-url>jdbc:postgresql://${postgresql.hostandport}/pam-simulator-PR-test</connection-url>
<driver-name>postgresql</driver-name>
<user-name>gazelle</user-name>
<password>gazelle</password>
<password>${postgresql.gazelle.password}</password>
</properties>
</resource>
</resources>
......@@ -23,11 +23,7 @@ SET row_security = off;
CREATE EXTENSION IF NOT EXISTS plpgsql WITH SCHEMA pg_catalog;
-- Name: EXTENSION plpgsql; Type: COMMENT; Schema: -; Owner:
COMMENT ON EXTENSION plpgsql IS 'PL/pgSQL procedural language';
SET default_tablespace = '';
......@@ -112,6 +112,7 @@
<dependencySourceIncludes>
<dependencySourceInclude>com.gitb.*</dependencySourceInclude>
</dependencySourceIncludes>
<javadocExecutable>${java.home}/bin/javadoc</javadocExecutable>
</configuration>
<executions>
<execution>
......@@ -218,7 +219,7 @@
<dependency>
<groupId>net.ihe.gazelle</groupId>
<artifactId>framework.logger-service</artifactId>
<version>1.0.0-SNAPSHOT</version>
<version>1.0.0</version>
</dependency>
<dependency>
<groupId>javax</groupId>
......@@ -229,7 +230,7 @@
<dependency>
<artifactId>lib.unit-test</artifactId>
</dependency>
<dependency>
......@@ -240,24 +241,24 @@
<dependency>
<artifactId>lib.gitb-processing-client</artifactId>
</dependency>
<dependency>
<artifactId>lib.search-model-api</artifactId>
<version>1.0.1</version>
</dependency>
<dependency>
<artifactId>lib.search-jpa-dao</artifactId>
</dependency>
<dependency>
<artifactId>lib.gitb-utils</artifactId>
</dependency>
<dependency>
