Commit c586793f authored by Malo Toudic's avatar Malo Toudic
Update pom.xml for pipeline
parent 2c1f2fad
Pipeline #271739 failed with stages
in 2 minutes and 40 seconds
...@@ -226,32 +226,49 @@ ...@@ -226,32 +226,49 @@
<profile> <profile>
<id>release</id> <id>release</id>
<activation> <build>
<property> <plugins>
<name>performRelease</name> <plugin>
<value>true</value> <groupId>org.sonatype.plugins</groupId>
</property> <artifactId>nexus-staging-maven-plugin</artifactId>
</activation> <version>${nexus.staging.maven.plugin.version}</version>
<executions>
<execution>
<id>default-deploy</id>
<phase>deploy</phase>
<goals>
<goal>deploy</goal>
</goals>
</execution>
</executions>
<configuration>
<serverId>nexus-releases</serverId>
<nexusUrl>https://gazelle.ihe.net/nexus</nexusUrl>
<skipStaging>true</skipStaging>
</configuration>
</plugin>
</plugins>
</build>
</profile> </profile>
<profile> <profile>
<id>sonar</id> <id>sonar</id>
<build> <build>
<plugins> <plugins>
<plugin> <plugin>
<groupId>org.sonarsource.scanner.maven</groupId> <groupId>org.sonarsource.scanner.maven</groupId>
<artifactId>sonar-maven-plugin</artifactId> <artifactId>sonar-maven-plugin</artifactId>
<version>3.5.0.1254</version> <version>${sonar.maven.plugin}</version>
<executions> <executions>
<execution> <execution>
<phase>verify</phase> <phase>verify</phase>
<goals> <goals>
<goal>sonar</goal> <goal>sonar</goal>
</goals> </goals>
</execution> </execution>
</executions> </executions>
</plugin> </plugin>
</plugins> </plugins>
</build> </build>
...@@ -287,12 +304,12 @@ ...@@ -287,12 +304,12 @@
</snapshots> </snapshots>
</pluginRepository> </pluginRepository>
</pluginRepositories> </pluginRepositories>
<distributionManagement> <distributionManagement>
<repository> <repository>
<id>nexus-releases</id> <id>nexus-releases</id>
<url>${nexus.url}/content/repositories/releases</url> <url>https://gazelle.ihe.net/nexus/content/repositories/releases</url>
</repository> </repository>
</distributionManagement> </distributionManagement>
<modules> <modules>
<module>gazelle-webservice-tester-ejb</module> <module>gazelle-webservice-tester-ejb</module>
