Commit fe90834c authored by POTTIER Francois's avatar POTTIER Francois
TODO.
parent 0f2e297f
...@@ -8,6 +8,10 @@ Better clean up & share code at the three call sites of [bulk]. ...@@ -8,6 +8,10 @@ Better clean up & share code at the three call sites of [bulk].
TODO (PERHAPS) TODO (PERHAPS)
Philip's question: when you compose two transformations formulated as map
visitors, can you deforest? (eliminate the allocation of the intermediate
tree)
Document Jonathan's example where every node in an "expression" carries a type Document Jonathan's example where every node in an "expression" carries a type
and the visitor for expressions carries the type down (whereas the visitor for and the visitor for expressions carries the type down (whereas the visitor for
types doesn't). types doesn't).
