Commit bd8db8c2 authored by POTTIER Francois's avatar POTTIER Francois
Clarification about ancestors.
parent 6b8cdabc
...@@ -1122,8 +1122,10 @@ form \oc|'self c as 'self|, where \oc|c| is a class. ...@@ -1122,8 +1122,10 @@ form \oc|'self c as 'self|, where \oc|c| is a class.
\begin{tabular}{@{}r@{\qquad}l@{\qquad}p{.6\textwidth}@{}} \begin{tabular}{@{}r@{\qquad}l@{\qquad}p{.6\textwidth}@{}}
\ancestors & (list of strings) & \ancestors & (list of strings) &
A list of classes that the generated class should inherit. A list of classes that the generated class should inherit.
The class \runtime{<variety>} is implicitly prepended to this list.
This is an optional parameter; its default value is the empty list. This is an optional parameter; its default value is the empty list.
Every ancestor class must have exactly \emph{one} type parameter,
which is typically (but not necessarily) the type of ``self''.
\concrete & (Boolean) & \concrete & (Boolean) &
If \oc|true|, the generated class is declared If \oc|true|, the generated class is declared
...@@ -1165,6 +1167,7 @@ form \oc|'self c as 'self|, where \oc|c| is a class. ...@@ -1165,6 +1167,7 @@ form \oc|'self c as 'self|, where \oc|c| is a class.
\end{figure} \end{figure}
\subsection{Parameters} \subsection{Parameters}
\label{sec:ancestors}
The parameters that can be passed as part of the The parameters that can be passed as part of the
...@@ -1175,17 +1178,11 @@ are described in \fref{fig:params}. ...@@ -1175,17 +1178,11 @@ are described in \fref{fig:params}.
% TEMPORARY % TEMPORARY
% document the shape of the generated code (per-type) % document the shape of the generated code (per-type)
% say that every generated class is self-parameterized
\label{sec:regularity} \label{sec:regularity}
% The regularity restriction. % The regularity restriction.
% The \ancestors parameter.
% documenter le fait que toutes nos classes sont paramétrées vis-à-vis du type
% de 'self, et les classes héritées via [ancestors] doivent suivre cette même
% convention.
\label{sec:opaque} \label{sec:opaque}
% The @opaque annotation. % The @opaque annotation.
(Note the parentheses, which are required.) (Note the parentheses, which are required.)
