Commit 3b4d2ae9 authored by POTTIER Francois's avatar POTTIER Francois
CHANGES.
parent 213535ee
...@@ -2,6 +2,8 @@ ...@@ -2,6 +2,8 @@
## 2017/11/24 ## 2017/11/24
* Added compatibility with OCaml 4.06.0.
* Fixed the internal function `occurs_type` in the case of polymorphic types. * Fixed the internal function `occurs_type` in the case of polymorphic types.
This should make no observable difference, as this function is used only This should make no observable difference, as this function is used only
to produce an error message in a corner case. to produce an error message in a corner case.
