Commit 22750666 authored by POTTIER Francois's avatar POTTIER Francois
TODO.
parent 3d8100cc
...@@ -2,10 +2,22 @@ ...@@ -2,10 +2,22 @@
TODO (REALLY) TODO (REALLY)
Allow & document @constructor for sum types and record types. beware of capture: code in @build can see some private variables
Document @build for sum types and record types.
Careful not to mis-spell it.
Unify the [body] functions for sums and records?
Also hoist the [body] functions for tuples and opaque types, for clarity.
Document hexpr_polymorphic.
Add a pointer to http://gallium.inria.fr/blog/from-visitors-to-iterators/ Add a pointer to http://gallium.inria.fr/blog/from-visitors-to-iterators/
mapreduce can serve to collect locations
create a new opam package visitorshashcons?
TODO (PERHAPS) TODO (PERHAPS)
...@@ -44,15 +56,6 @@ Maybe [fold] and [fold2] in VisitorsRuntime should just be aliases ...@@ -44,15 +56,6 @@ Maybe [fold] and [fold2] in VisitorsRuntime should just be aliases
Once we have that, can we deal with GADTs? Once we have that, can we deal with GADTs?
Ancestors should be not just class names,
but class expressions (e.g. a class name applied to some arguments).
Then, one should also have the ability of parameterizing
the generated visitor with value arguments.
This could be used to define visit_hash_consed once and for all,
in a clean way, as a base class that could be inherited,
taking the memoization table as an argument.
See hexpr_polymorphic.ml.
In [fold], In [fold],
the build_ methods could take not only the results of the recursive calls, the build_ methods could take not only the results of the recursive calls,
but also their arguments (for added expressive power). but also their arguments (for added expressive power).
...@@ -85,16 +88,6 @@ Avoid generating beta-redexes. ...@@ -85,16 +88,6 @@ Avoid generating beta-redexes.
Re-introduce hoisting of closure allocations of the form [self#visit_foo]? Re-introduce hoisting of closure allocations of the form [self#visit_foo]?
If so, share them when they have several occurrences. If so, share them when they have several occurrences.
[variety] could be a list.
But then, one would need to replace <variety> with variety in
[ancestors] and in [name] (if present).
Somewhat tricky, as we would need to produce not one settings
record, but several of them.
Implement a way of deferring visitor generation.
(inserting user code between the type definition and the visitor class)
(or, more generally, generating a visitor for a pre-existing type)
Do something about ~path? Do something about ~path?
It seems connected to nested modules. It seems connected to nested modules.
