Une MAJ de sécurité est nécessaire sur notre version actuelle. Elle sera effectuée lundi 02/08 entre 12h30 et 13h. L'interruption de service devrait durer quelques minutes (probablement moins de 5 minutes).
Commit b6080a98 authored by POTTIER Francois's avatar POTTIER Francois
Misc edits in the blog post.
parent 6c2d6126
......@@ -53,7 +53,8 @@ iterators. A cascade is a persistent (stateless) iterator. It can be thought
of as a delayed list, that is, a list whose elements are computed only on
demand.
Cascades could (should) be part of a separate library. There is in fact
As the time of writing (March, 2017), there is in fact
[a proposal](https://github.com/ocaml/ocaml/pull/1002)
to add them to OCaml's standard library.
......@@ -67,10 +68,6 @@ and 'a head =
A delayed computation is represented as a function of type `unit -> _`.
Thus, no memoization takes place. It is easy to implement a function
`memo: 'a cascade -> 'a cascade` that turns a nonmemoizing cascade into
a memoizing one, so memoization can be requested a posteriori, if
desired.
The empty cascade is defined as follows:
......@@ -147,10 +144,12 @@ type 'a delayed_tree =
| DTDelay of (unit -> 'a delayed_tree)
A delayed tree is converted to a cascade as follows. We may choose, at this
point, between left-to-right and right-to-left traversals. As usual, when
building a cascade, one must take a continuation `k` as an argument, so as
to avoid naive and costly cascade concatenation operations.
A delayed tree is converted to a cascade as follows. As is often the case,
when building a cascade, one must take a continuation `k` as an argument, so
as to avoid naive and costly cascade concatenation operations. Thus, the
specification of the function call `delayed_tree_to_cascade dt k` is to
construct a cascade whose elements are the elements of the delayed tree `dt`
(listed from left to right), followed with the elements of the cascade `k`.
let rec delayed_tree_to_cascade (dt : 'a delayed_tree) (k : 'a cascade)
......@@ -175,7 +174,10 @@ let delayed_tree_to_iterator (dt : 'a delayed_tree) : 'a iterator =
cascade_to_iterator (delayed_tree_to_cascade dt)
## Constructing delayed trees
In the above code, we have chosen to perform a left-to-right traversal of
the delayed tree, but could just as well have chosen a right-to-left traversal.
## Constructing Delayed Trees
The type `'a delay` is a synonym for `'a`. We will use it as a decoration, in
a type definition, to indicate that a call to the method `visit_delay` is
