Commit 36e1ec8c authored by POTTIER Francois's avatar POTTIER Francois
Typo.
parent 91271e8b
...@@ -580,7 +580,7 @@ just a matter of performing a synchronous traversal of the two expressions and ...@@ -580,7 +580,7 @@ just a matter of performing a synchronous traversal of the two expressions and
detecting a \oc|StructuralMismatch| exception: if this exception is raised, detecting a \oc|StructuralMismatch| exception: if this exception is raised,
one must return \oc|false|, otherwise one must return \oc|true|. We rely on one must return \oc|false|, otherwise one must return \oc|true|. We rely on
the fact that the method \tyconvisitor{int}, which is inherited from the class the fact that the method \tyconvisitor{int}, which is inherited from the class
\runtime{iter2}, fails when its two integer argument are \runtime{iter2}, fails when its two integer arguments are
unequal. unequal.
The convenience functions \runtime{wrap} and The convenience functions \runtime{wrap} and
