Une MAJ de sécurité est nécessaire sur notre version actuelle. Elle sera effectuée lundi 02/08 entre 12h30 et 13h. L'interruption de service devrait durer quelques minutes (probablement moins de 5 minutes).
Commit 1147fd0d authored by POTTIER Francois's avatar POTTIER Francois
Shorter types.
parent 8008854b
...@@ -24,13 +24,13 @@ type tyvars = tyvar list ...@@ -24,13 +24,13 @@ type tyvars = tyvar list
(* [select name attrs] extracts the attribute named [name] from the attribute (* [select name attrs] extracts the attribute named [name] from the attribute
list [attrs]. *) list [attrs]. *)
let select (name : string) (attrs : attribute list) : attribute option = let select (name : string) (attrs : attributes) : attribute option =
attr ~deriver:plugin name attrs attr ~deriver:plugin name attrs
(* [present name attrs] tests whether an attribute named [name] is present (* [present name attrs] tests whether an attribute named [name] is present
(with no argument) in the list [attrs]. *) (with no argument) in the list [attrs]. *)
let present (name : string) (attrs : attribute list) : bool = let present (name : string) (attrs : attributes) : bool =
Arg.get_flag ~deriver:plugin (select name attrs) Arg.get_flag ~deriver:plugin (select name attrs)
(* [opacity attrs] tests whether the attribute list [attrs] contains an (* [opacity attrs] tests whether the attribute list [attrs] contains an
