Lecture 5 goes live
parent 4c427b05
{-# OPTIONS --no-positivity-check --allow-unsolved-metas --rewriting #-}
module 05-open.Problems where
open import Data.Product
open import Data.Nat
open import Data.List renaming (_++_ to _++L_)
open import Data.Vec
open import Relation.Binary.PropositionalEquality
Open problems
In this course, we have seen that there may be such a thing as
"dependently-typed programming" after all. We saw that it can be:
- effectufl (lecture 1)
- correct-by-construction (lecture 2)
- structurally recursive or not (lecture 3)
- generic (lecture 4)
And it is not just "as good as" languages of the ML family: it enables
genuinely novel and interesting forms of programming.
However, some would argue that programming with dependent type is
unbearably difficult (watch out for disgruntled Coq users). They may
not be absolutely right but perhaps not absolutely wrong either. For
instance, we never had to perform a type cast along a propositional
equality: this is too good to be true. In this last lecture, we
explain why we were able to write these programs so elegantly, we
dissect a few *bad* programs and highlight some very *ugly* (or
impossible) ones.
This time, we shall not try to come to a conclusion: we are touching
upon research questions, only the future will tell whether the AI
robot take over the planet will be programmed with Haskell type
families, C++ template, or ANSI C.
The Good
We review a few, salient definitions of each lecture. For the
definitions I had to come up with myself or had to reconstruct from a
paper, I provide an estimate of the time it took me to find the
"right" definition (Conor McBride talks about the act of "engineering
coincidences"). This measure must be interpreted in relative terms as
I am, after all, only a moderately clever person with only one PhD
(whose topic was on programming in the inductive fragment of type
theory).
Lecture 0: The Evolution of a Typechecker
The tricky definition is the typechecker itself
.. code-block:: agda
_?__ : (Γ : context)(T : type)(t : term ) Γ [ ]-view T t
_?_ : (Γ : context)(t : term ) Γ [ ]-view t
that uses ``_[_]-view_`` to ensure that the type-checking or
type-failing derivation produced corresponds to the original term
through the forgetful function ``_``:
data _[_]-view_ (Γ : context)(d : dir) : Dir d Set where
yes : {T} (Δ : Γ [ d ] T) Γ [ d ]-view Δ
no : {T} (¬Δ : Γ [ d ] T) Γ [ d ]-view ¬Δ
The trick is to notice that not only is the function ``_`` injective
but it is also merely mapping each **constructor** of the source
datatype to a constructor of the target datatype. Therefore, as we
pattern match on derivations, the type becomes more precise by
revealing a constructor and therefore the forgetful function
mechanically unfolds. If the forgetful map was recursively non
trivial, it would have been another story.
**Estimated time:** It took me about 3 weeks of full-time work to
converge on the final implementation of the type-checker. I initially
thought that I could exploit a monad-generic implementation of the
type-checker to use it for type-directed parsing & pretty-printing but
this was incompatible with the dependently-typed implementation for
which it is not clear how to write it monadically, let alone
monad-generically.
Lecture 1: Effects
The programs we wrote were simply typed so we had it
easy. Nonetheless, we were not able to write the generic definition of
the free monad, which would be::
data Free (F : Set Set)(X : Set) : Set where
return : X Free F X
op : F (Free F X) Free F X
because the positivity-checker would reject this definition: ``F``
provides no guarantee that it will use ``Free F X`` in a
strictly-positive position. This is one of those instances were
relying exclusively on oracles as a way of introducing definitions
impedes compositionality. We have seen in Lecture 4 that it could be
addressed by reflecting inductive types in the type theory itself.
Lecture 2: Indices
Good news, using inductive families for typing ``sprintf`` seems to
qualify as `industrial-strength
<https://ocaml.org/meetings/ocaml/2013/proposals/formats-as-gadts.pdf>`_,
being faster and safer that the untyped alternative.
The expression and machine code are indexed by a type-level tag, which
is almost literally transferred by the compiler
compile : {T σ} exp T code σ (T σ)
If significantly distinct types were used on either side of the
compiler, a non-trivial translation function would be necessary to
state the type of the compiler
compile : {T σ} exp T code σ (non-trivial T σ)
which would probably make for a few sleepless nights and type-casting
proofs.
The difficulty of the normalization-by-evaluation program is mostly
conceptual: to deal with binders, one must construct the right model,
which was an issue for category theorists before being one for
dependently-typed programmers.
As part of this exercise, we saw a structural definition of
substitution: this is a folklore trick (that I learned from Conor
McBride), meaning that we can assume that countless hours were spent
by the first person that tried implementing it. Note that it is not a
particularly efficient implementation.
**Estimated time:** It took me about 2 days of full-time work, mostly
studying the literature, to extract the right abstractions to write
the normalization-by-evaluation program. However, dependent types were
instrumental in forcing me to identify these abstractions: in a
simply-typed setting, there is no incentive to do this effort (or one
end up doing pure category theory).
Lecture 3: Recursion
The representation of terms for the MGU relies once again on the
folkore representation of well-scoped terms.
The recursion scheme justifying the proof search was found and
explained by McBride. This is indeed hard work but that needs to be
done anyway. It could be done in a proof-irrelevant manner (using an
accessibility predicate to justify the general-recursive definition,
for example) or in a proof-relevant manner (which is what we did
here).
**Estimated time:** It took me about 5 days of full-time work to
translate the ideas set forward in McBride's Djinn Monotonic into a
workable implementation. Knowing which datatype to define (it is given
by the paper) and the overall recursion scheme is but one small step:
writing a (correct) implementation handling ordered formuli was far
from trivial. For instance, the straightforward zipper is gone,
replaced by a head-scratching search procedure.
Lecture 4: Generic programming
Programming with algebraic structures was made possible by the
availability of instance arguments (ie. type-classes) in
Agda. However, not all objects lend themselves to being
instances. Attaching structures to (inductive) type formers works like
a charm, since the unifier can rely on a concrete object (the type
former) to drive the instance search.
Attaching structure to a compute type did not work at all. For
instance, I was not able to define any (useful) instance for the
functor ``Hyper Fs``::
Hyper : List (Set → Set) → Set → Set
Hyper [] A = A
Hyper (F ∷ Fs) A = Hyper Fs (F A)
As a poor man's alternative, I reified the identity and composition of
functors as inductive type formers::
data Id (A : Set) : Set where
I : A Id A
data Seq (G : Set Set)(F : Set Set)(A : Set) : Set where
S : F (G A) Seq G F A
and attached structure to those: when ``Hyper`` computes, it will
reveal a chain of ``Seq``, potentially closed by an ``Id``, all of
which have the structures wwe are interested in. However, this is not
a silver bullet: on ``Hyper Fs``, with ``Fs`` a quantified variable,
we cannot access any of its structure. We cannot rely on ad-hoc
polymorphism and must manually instantiate the dictionaries.
Also, the paper becomes really interesting in Section 6, in which
alignment between matrices of different dimensions is automatically
computed through the following (simplified) type family:
.. code-block:: guess
instance Alignable (F Fs) (F Gs) where
instance Alignable [] (F Fs) where
From a type-theoretic point of view, the first instance is
meaningless: what does it mean for ``F : Set Set`` to be "equal" on
both sides? Equality of functions is notoriously ill-behaved in type
theory. I therefore stopped right before Section 6, retreating from a
doomed attempt: the very definition of ``hyper`` as ``List (Set
Set)`` was already an admission of defeat.
The definition of the ``Desc`` was suspiciously redundant: the sum
product (``_`+_``) codes could have been simulated by ``Π Bool λ {
true _ ; false _ }``. However, the former encoding enables a
purely first-order implementation (as an inductively-defined sum)
whereas the latter involves a function type. First, intensional
equality is not well-behaved (understand: useless) on functions, hence
a general tendency to avoid them at all cost. Second, having sums
allows us to levitate the description of descriptions as a purely
first-order object (no function lying around).
Other examples
The Mathcomp library defines `tuples
<https://math-comp.github.io/math-comp/htmldoc/mathcomp.ssreflect.tuple.html>`_,
which are equivalent to our very own vector. However, rather than
defining an inductive family, a tuple of size ``n`` is implemented as
"a list whose length is n". Crucially, the constraint that the length
is equal to n does **not** use propositional equality but decidable
equality over natural numbers:
.. code-block:: coq
Structure tuple_of : Type := Tuple {tval :> seq T; _ : size tval == n}.
`Hedberg theorem <https://doi.org/10.1017/S0956796898003153>`_ tells
us that this implies that two tuples are equal if and only if they
package the same list (irrespectively of the proof that established
that these lists are of the right size). This is not an issue in
Vanilla Agda, for which all proofs of equality are equal ("uniqueness
of identity proofs", UIP). It is in Coq or in Agda with the flag
"--without-k".
Aside from allowing us to avoid relying on UIP, this style also
enables the definition of operations on vectors (concatenation,
reversal, etc.) to directly re-use the existing operations on lists:
one just need to prove that the constraints on lengths are respected.
The Bad
Gibbons definition of hyper-matrices is given as a (nested) datatype::
data Hyper' (A : Set) : List (Set → Set) → Set where
Scalar : A → Hyper' A []
Prism : {F Fs} Hyper' (F A) Fs → Hyper' A (F Fs)
Once again, this definition would not be manageable in type theory
because it implicitly introduces propositional equality to enforce the
constraint ``Hyper A (F Fs)`` in the target of the Prism
constructor, which is meaningless for the function ``F``.
Sometimes, even apparently good definitions, such as the pervasive
vectors, are behaving frustratingly. In each of the following
examples, we shall give a working definition with lists and a
computationally-equivalent but non-working version on vectors. The
point is not that the desired functionality *cannot* be implemented
(most of the time, one can rewrite them to side-step the problem) but
rather that a "morally correct" definition or property is forbidden.
The first example is a failure of compositionality, first between two functions::
module NCons-List (A : Set) where
ncons : A List A List A
ncons zero a vs = vs
ncons (suc m) a vs = a ncons m a vs
nseq : A List A
nseq m a = ncons m a []
module NCons-Vec (A : Set) where
ncons : {n} (m : ) A Vec A n Vec A (m + n)
nseq : (m : ) A Vec A m
nseq m a = {!ncons m a []!}
-- m + zero != m of type ℕ
-- when checking that the expression ncons m a [] has type Vec A m
and, second, between a single (recursive) function::
module RCons-List (A : Set) where
_++r_ : {A : Set} List A List A List A
[] ++r ys = ys
(x xs) ++r ys = xs ++r (x ys)
module RCons-Vec (A : Set) where
_++r_ : {A : Set}{m n} Vec A m Vec A n Vec A (n + m)
[] ++r ys = {!ys!}
-- .n != .n + 0 of type ℕ
-- when checking that the expression ys has type Vec .A (.n + 0)
(x xs) ++r ys = {!xs ++r (x ∷ ys)!}
-- suc (.n + .n) != .n₁ + suc .n of type ℕ
-- when checking that the expression xs ++r (x ys) has type Vec .A (.n + suc .n)
This sort of annoyance also happens when stating properties::
module Cats-List (A : Set) where
cats0 : (v : List A) v ++L [] v
cats0 [] = refl
cats0 (x v) rewrite cats0 v = refl
module Cats-Vec (A : Set) where
cats0 : {n} (v : Vec A n) v ++ [] {!v!}
-- n != n + zero of type ℕ
-- when checking that the expression v has type Vec A (n + zero)
cats0 = {!!}
which means that some proofs are themselves impossible to do
compositionally since the necessary lemmas are simply not
expressible::
module Rcons-List (A : Set) where
rcons : List A A List A
rcons [] a = a []
rcons (x xs) a = x rcons xs a
last' : (a : A) → List A → A
last' a [] = a
last' _ (a ∷ xs) = last' a xs
last-rcons : x s z last' x (rcons s z) ≡ z
last-rcons x s z = trans (cong (last' x) (cat1 s z)) (last-cat x s (z []))
where postulate
last-cat : x (s : List A)(s : List A) last' x (s₁ ++L s₂) ≡ last' (last' x s₁) s₂
cat1 : ∀ s z → rcons s z ≡ s ++L (z ∷ [])
module Rcons-Vec (A : Set) where
rcons : ∀ {n} → Vec A n → A → Vec A (suc n)
rcons [] a = a ∷ []
rcons (x ∷ xs) a = x ∷ rcons xs a
last' : {n} (a : A) Vec A n A
last' a [] = a
last' _ (a xs) = last' a xs
postulate
last-cat : ∀ {m n} x (s₁ : Vec A m)(s₂ : Vec A n) → last' x (s ++ s) last' (last' x s) s
cat1 : {n} (s : Vec A n) z rcons s z {!s ++ (z ∷ [])!}
-- n + suc zero != suc n of type ℕ
-- when checking that the expression s ++ z [] has type Vec A (suc n)
last-rcons : {n} x (s : Vec A n) z last' x (rcons s z) ≡ z
last-rcons {n} x s z = trans {!cong (last' {suc n / n + 1}) ?!} (last-cat x s (z ∷ []))
-- Heterogeneous equality necessary
An elegant solution (due to `Conor McBride
<http://strictlypositive.org/thesis.pdf>`_) to the problem of stating
and using the above equalities consists in generalizing slightly the
definition of equality so that it becomes **heterogeneous**::
data __ {A : Set} (x : A) : {B : Set} B Set where
refl : x x
However, we are still at a loss to write programs such as ``nseq`` or
``_++r_`` in a compositional, proof-free manner.
The Ugly
Nested datatypes, such as::
data Bush (A : Set) : Set where
leaf : A Bush A
node : Bush (A × A) Bush A
size : {A} Bush A
size (leaf x) = 1
size (node b) = let n = size b in n + n
are slightly suspicious in the sense that the constructors are
actually encoding the *size* of the container, the constructor
``leaf`` containing a tuple whose shape is determined by the previous
``node`` constructors. First, programming with such a definition is
not going to be pleasant. Second, to encode structural properties, we
have a better tool at hand: indices and inductive families!
Addressing the second point, one could write::
data Bush' (A : Set)(n : ℕ) : Set where
leaf : Vec A n → Bush' A n
node : Bush' A (n + n) → Bush' A n
Addressing the first point, one realizes that Peano numbers are not
the right fit for indexing this structure::
data Bin : Set where
#0 : Bin
#1 : Bin Bin
to : Bin
to #0 = 1
to (#1 n) = let x = to n in x + x
data Bush'' (A : Set) : Bin Set where
leaf : A Bush'' A #0
node : {n} Bush'' A n Bush'' A n Bush'' A (#1 n)
.. Local Variables:
.. mode: agda2
.. End:
......@@ -12,6 +12,19 @@ MPRI 2.4 : Dependently-typed Functional Programming
open import 02-dependent.Indexed
open import 03-total.Recursion
open import 04-generic.Desc
open import 05-open.Problems
This course is organized as follows:
.. toctree::
:maxdepth: 1
00-agda/Warmup
01-effectful/Monad
02-dependent/Indexed
03-total/Recursion
04-generic/Desc
05-open/Problems
