Typo
parent b8fd772a
...@@ -161,7 +161,7 @@ The deadline is **Friday, February 16, 2018**. ...@@ -161,7 +161,7 @@ The deadline is **Friday, February 16, 2018**.
* [Effectful functional programming](slides/pedagand-01.pdf) ([Source](agda/01-effectful/Monad.lagda.rst)). * [Effectful functional programming](slides/pedagand-01.pdf) ([Source](agda/01-effectful/Monad.lagda.rst)).
* [Dependent functional programming](slides/pedagand-02.pdf) ([Source](agda/02-dependent/Indexed.lagda.rst), [McCompiler.v](coq/McCompiler.v)). * [Dependent functional programming](slides/pedagand-02.pdf) ([Source](agda/02-dependent/Indexed.lagda.rst), [McCompiler.v](coq/McCompiler.v)).
* [Total functional programming](slides/pedagand-03.pdf) ([Source](agda/03-total/Recursion.lagda.rst)). * [Total functional programming](slides/pedagand-03.pdf) ([Source](agda/03-total/Recursion.lagda.rst)).
* ]Generic functional programming](slides/pedagand-04.pdf) ([Source](agda/04-generic/Desc.lagda.rst)). * [Generic functional programming](slides/pedagand-04.pdf) ([Source](agda/04-generic/Desc.lagda.rst)).
* Open problems in dependent functional programming. * Open problems in dependent functional programming.
## Evaluation of the course ## Evaluation of the course
