Lecture 2 goes live
parent 4787aea3
...@@ -161,7 +161,7 @@ The deadline is **Friday, February 16, 2018**. ...@@ -161,7 +161,7 @@ The deadline is **Friday, February 16, 2018**.
* [Guidelines](agda/Index.lagda.rst) * [Guidelines](agda/Index.lagda.rst)
* [Effectful functional programming](slides/pedagand-01.pdf) ([Source](agda/01-effectful/Monad.lagda.rst)). * [Effectful functional programming](slides/pedagand-01.pdf) ([Source](agda/01-effectful/Monad.lagda.rst)).
* Dependent functional programming. * [Dependent functional programming](slides/pedagand-02.pdf) ([Source](agda/02-dependent/Indexed.lagda.rst), [McCompiler.v](coq/McCompiler.v)).
* Total functional programming. * Total functional programming.
* Generic functional programming. * Generic functional programming.
* Open problems in dependent functional programming. * Open problems in dependent functional programming.
This diff is collapsed.
...@@ -9,6 +9,7 @@ MPRI 2.4 : Dependently-typed Functional Programming ...@@ -9,6 +9,7 @@ MPRI 2.4 : Dependently-typed Functional Programming
open import 00-agda.Warmup open import 00-agda.Warmup
open import 01-effectful.Monad open import 01-effectful.Monad
open import 02-dependent.Indexed
