Commit fe74a277 authored by POTTIER Francois's avatar POTTIER Francois
Added abstract syntax for anonymous rules. Unused, for now.
parent 47bb88b9
...@@ -229,7 +229,7 @@ let check positions env k expected_type = ...@@ -229,7 +229,7 @@ let check positions env k expected_type =
(* An identifier can be used either in a total application or as a (* An identifier can be used either in a total application or as a
higher-order non terminal (no partial application is allowed). *) higher-order nonterminal (no partial application is allowed). *)
let rec parameter_type env = function let rec parameter_type env = function
| ParameterVar x -> | ParameterVar x ->
lookup x.value env lookup x.value env
...@@ -248,6 +248,10 @@ let rec parameter_type env = function ...@@ -248,6 +248,10 @@ let rec parameter_type env = function
[Star] otherwise it is the flexible variable. *) [Star] otherwise it is the flexible variable. *)
star_variable star_variable
| ParameterAnonymous _ ->
(* Anonymous rules are eliminated early on. *)
assert false
let check_grammar (p_grammar : Syntax.grammar) = let check_grammar (p_grammar : Syntax.grammar) =
(* [n] is the grammar size. *) (* [n] is the grammar size. *)
let n = StringMap.cardinal p_grammar.p_rules in let n = StringMap.cardinal p_grammar.p_rules in
...@@ -446,14 +450,23 @@ let rec subst_parameter subst = function ...@@ -446,14 +450,23 @@ let rec subst_parameter subst = function
| ParameterApp _ -> | ParameterApp _ ->
(* Type-checking ensures that we cannot do partial (* Type-checking ensures that we cannot do partial
application. Consequently, if an higher-order non terminal application. Consequently, if a higher-order nonterminal
is an actual argument, it cannot be the result of a is an actual argument, it cannot be the result of a
partial application. *) partial application. *)
assert false assert false
assert false
with Not_found -> with Not_found ->
ParameterApp (x, List.map (subst_parameter subst) ps)) ParameterApp (x, List.map (subst_parameter subst) ps))
assert false
let subst_parameters subst = let subst_parameters subst =
List.map (subst_parameter subst) List.map (subst_parameter subst)
...@@ -513,6 +526,11 @@ let expand p_grammar = ...@@ -513,6 +526,11 @@ let expand p_grammar =
(Positions.value x) (Positions.value x)
(separated_list_to_string mangle "," ps) (separated_list_to_string mangle "," ps)
assert false
in in
let name_of symbol parameters = let name_of symbol parameters =
let param = ParameterApp (symbol, parameters) in let param = ParameterApp (symbol, parameters) in
...@@ -540,6 +558,10 @@ let expand p_grammar = ...@@ -540,6 +558,10 @@ let expand p_grammar =
assert (actual_parameters = []); assert (actual_parameters = []);
x, ps x, ps
assert false
sym, subst_parameters subst actual_parameters sym, subst_parameters subst actual_parameters
in in
...@@ -10,57 +10,62 @@ let app p ps = ...@@ -10,57 +10,62 @@ let app p ps =
| _ -> | _ ->
ParameterApp (p, ps) ParameterApp (p, ps)
let oapp1 o p =
match o with
| None ->
p
| Some var ->
ParameterApp (var, [ p ])
let unapp = function let unapp = function
(x, []) (x, [])
| ParameterApp (p, ps) -> | ParameterApp (p, ps) ->
(p, ps) (p, ps)
assert false
let rec map f = function let rec map f = function
ParameterVar (f x) ParameterVar (f x)
ParameterApp (f p, List.map (map f) ps) ParameterApp (f p, List.map (map f) ps)
assert false
let rec fold f init = function let rec fold f init = function
f init x f init x
f (List.fold_left (fold f) init ps) p f (List.fold_left (fold f) init ps) p
assert false
let identifiers m p = let identifiers m p =
fold (fun acu x -> StringMap.add x.value x.position acu) m p fold (fun accu x -> StringMap.add x.value x.position accu) m p
type t = parameter type t = parameter
let rec equal x y = let rec equal x y =
match x, y with match x, y with
| ParameterVar x, ParameterVar y when x.value = y.value -> | ParameterVar x, ParameterVar y ->
true x.value = y.value
| ParameterApp (p1, p2), ParameterApp (p1', p2') -> | ParameterApp (p1, p2), ParameterApp (p1', p2') ->
p1.value = p1'.value && List.for_all2 equal p2 p2' p1.value = p1'.value && List.for_all2 equal p2 p2'
| _ -> false | _ ->
false
let hash = function let hash = function
| ParameterVar x | ParameterVar x
| ParameterApp (x, _) -> | ParameterApp (x, _) ->
Hashtbl.hash (Positions.value x) Hashtbl.hash (Positions.value x)
assert false
let position = function let position = function
Positions.position x Positions.position x
| ParameterAnonymous bs ->
Positions.position bs
let with_pos p = let with_pos p =
Positions.with_pos (position p) p Positions.with_pos (position p) p
...@@ -434,30 +434,25 @@ let iter_on_only_used_symbols f t = ...@@ -434,30 +434,25 @@ let iter_on_only_used_symbols f t =
let symbols_of grammar (pgrammar : Syntax.partial_grammar) = let symbols_of grammar (pgrammar : Syntax.partial_grammar) =
let tokens = grammar.p_tokens in let tokens = grammar.p_tokens in
let symbols_of_rule symbols prule = let symbols_of_rule symbols prule =
let rec store_except_rule_parameters = let rec store_except_rule_parameters symbols parameter =
fun symbols (symbol, parameters) -> let symbol, parameters = Parameters.unapp parameter in
(* Rule parameters are bound locally, so they are not taken into (* Rule parameters are bound locally, so they are not taken into account. *)
account. *) if List.mem symbol.value prule.pr_parameters then
if List.mem symbol.value prule.pr_parameters then (* TEMPORARY probable BUG: even if the symbol is locally bound, its
symbols parameters should still be examined! *)
else symbols
(* Otherwise, mark this symbol as being used and analyse its else
parameters. *) (* Otherwise, mark this symbol as used and analyse its parameters. *)
List.fold_left List.fold_left
(fun symbols -> function store_except_rule_parameters
| ParameterApp (symbol, parameters) -> (store_used_symbol symbol.position tokens symbols symbol.value)
store_except_rule_parameters symbols (symbol, parameters) parameters
| ParameterVar symbol ->
store_except_rule_parameters symbols (symbol, [])
(store_used_symbol symbol.position tokens symbols symbol.value) parameters
in in
(* Analyse each branch. *) (* Analyse each branch. *)
let symbols = List.fold_left (fun symbols branch -> let symbols = List.fold_left (fun symbols branch ->
List.fold_left (fun symbols (_, p) -> List.fold_left (fun symbols (_, p) ->
let symbol, parameters = Parameters.unapp p in store_except_rule_parameters symbols p
) symbols branch.pr_producers ) symbols branch.pr_producers
) symbols prule.pr_branches ) symbols prule.pr_branches
in in
...@@ -593,18 +588,13 @@ let check_parameterized_grammar_is_well_defined grammar = ...@@ -593,18 +588,13 @@ let check_parameterized_grammar_is_well_defined grammar =
"the type of the start symbol %s is unspecified." nonterminal; "the type of the start symbol %s is unspecified." nonterminal;
) grammar.p_start_symbols; ) grammar.p_start_symbols;
let parameter_head_symb = function
| ParameterVar id -> id
| ParameterApp (id, _) -> id
in
(* Every %type definition has, at its head, a nonterminal symbol. *) (* Every %type definition has, at its head, a nonterminal symbol. *)
(* Same check for %on_error_reduce definitions. *) (* Same check for %on_error_reduce definitions. *)
(* Apparently we do not check the parameters at this point. Maybe this is (* Apparently we do not check the parameters at this point. Maybe this is
done later, or not at all. *) done later, or not at all. *)
let check (kind : string) (ps : Syntax.parameter list) = let check (kind : string) (ps : Syntax.parameter list) =
List.iter (fun p -> List.iter (fun p ->
let head_symb = parameter_head_symb p in let (head_symb, _) = Parameters.unapp p in
if not (StringMap.mem (value head_symb) grammar.p_rules) then if not (StringMap.mem (value head_symb) grammar.p_rules) then
Error.error [Parameters.position p] Error.error [Parameters.position p]
"this should be a nonterminal symbol.\n\ "this should be a nonterminal symbol.\n\
...@@ -72,52 +72,6 @@ type token_properties = ...@@ -72,52 +72,6 @@ type token_properties =
(* A parameter is either just a symbol, or an application of a symbol to
a tuple of parameters. *)
type parameter =
| ParameterVar of symbol Positions.located
| ParameterApp of symbol Positions.located * parameters
and parameters =
parameter list
(* A declaration. (Only before joining.) *)
type declaration =
(* Raw OCaml code. *)
| DCode of Stretch.t
(* Raw OCaml functor parameter. *)
| DParameter of Stretch.ocamltype (* really a stretch *)
(* Terminal symbol (token) declaration. *)
| DToken of Stretch.ocamltype option * terminal
(* Start symbol declaration. *)
| DStart of nonterminal
(* Priority and associativity declaration. *)
| DTokenProperties of terminal * token_associativity * precedence_level
(* Type declaration. *)
| DType of Stretch.ocamltype * parameter
(* On-error-reduce declaration. *)
| DOnErrorReduce of parameter
(* A [%prec] annotation is optional. A production can carry at most one. (* A [%prec] annotation is optional. A production can carry at most one.
If there is one, it is a symbol name. See [ParserAux]. *) If there is one, it is a symbol name. See [ParserAux]. *)
...@@ -134,17 +88,31 @@ type branch_production_level = ...@@ -134,17 +88,31 @@ type branch_production_level =
(* A parameter is either just a symbol or an application of a symbol to a
nonempty tuple of parameters. Before anonymous rules have been eliminated,
it can also be an anonymous rule, represented as a list of branches. *)
type parameter =
| ParameterAnonymous of parameterized_branch list Positions.located
and parameters =
parameter list
(* A producer is a pair of identifier and a parameter. In concrete syntax, (* A producer is a pair of identifier and a parameter. In concrete syntax,
it could be [e = expr], for instance. *) it could be [e = expr], for instance. *)
type producer = and producer =
identifier Positions.located * parameter identifier Positions.located * parameter
(* A branch contains a series of producers and a semantic action. *) (* A branch contains a series of producers and a semantic action. *)
type parameterized_branch = and parameterized_branch =
pr_branch_position : Positions.t; pr_branch_position : Positions.t;
pr_producers : producer list; pr_producers : producer list;
...@@ -169,6 +137,40 @@ type parameterized_rule = ...@@ -169,6 +137,40 @@ type parameterized_rule =
type declaration =
| DCode of Stretch.t
(* A partial grammar. (Only before joining.) *) (* A partial grammar. (Only before joining.) *)
type partial_grammar = type partial_grammar =
